16 years agoproblem Master LCD of Read/write in cyclone II with vhdl
hello, i would to create my master of read and write in LCD in the cyclone II but before start write and read i would write the code of Initialization of the LCD in cyclone II wit...
16 years agoHi, you speak French :)
Your English writing is not very good. We continue to write in English so that others can understand. You don't have a reset signal and/or a RAZ. i suggest you to add reset signal.process (reset_n, clk)
begin
if reset_n = '0' then
-- all init here
elsif rising_edge(clk) then
-- all synchronous signal here
end if;
end process; One of good coding style is to not make Initialization in signal declarations because of synthesis tool. Minor : when you declare "integer", better is to specify "integer range 0 to 250" for ex. maybe your proc_state is not initialize to '0' Major : You have to be most rigorous when writing process : in line 111 (--process pour l'initialisation envoie sequentiel des données) you should write "process(g_clk)" Amicalement,
