14 years agoport assignment in vhdl
hi all, i am new to VHDL and this question may be easy for you.my question is:
how can i assign value to an in port?my port declaration is: DATA_I : in std_logic_vector(7 downto 0); i am trying to assign a value above but simulator says that a port can not be driven.do you have any idea?5 Replies
An in port represents an external input to your logic. It can't be driven internally. What do you want to achieve?
thanks for replies.i am trying to debug my VHDL program, i use a simulator for this.how can i give values to in port for debuging?
In a simulator, the design under test will be instantiated in a testbench. There you can drive input and inout ports and also force internal signals, if necessary.
thank you, i will try to do UUT issue in the simulator.
