16 years agoPCIe core MSI-X support
I have added MSI-X support to an implementation of the Altera PCIe core we're already testing in the lab. My understanding, is that with MSI-X enabled in the megawizard and my vector table offset set appropriately, I have created the vector table in my own register set at that offset. I then, as I understand it, trigger an MSI-X interrupt simply by issueing a single DW PCIe Memory Write to the appropriate MSI-X address with the appropriate data, as specified in the vector table. As I understand it, the specific MSI I/O to the core isn't used for MSI-X, and you just do a normal memory write.
However, my write doesn't seem to appear in shared memory in the simulation. I'm not sure what I'm doing wrong. Is my above understanding correct? I have other data moving back and forth over the link without trouble. I notice that in the shared memory the code 0x00207811 appears, in the first interrupt address, even with no interrupt happening, image attached. Also attached is a wave view of my MSI-X single DW write.
