16 years agoPCIe core MSI-X support
I have added MSI-X support to an implementation of the Altera PCIe core we're already testing in the lab. My understanding, is that with MSI-X enabled in the megawizard and my vector table offset se...
16 years ago --- Quote Start --- The address looks strange indeed. Can you trap the write accesses to these registers and look what address Linux actually writes, on the AST level (as write data)? Is your MSI-X Table handler prepared for all kinds of write accesses, especially if they are aggregated? --- Quote End --- I'm support no more than 64bit burst. Because I'm read x86 CPU can't generate burst bigger. I will check. Other's registers works ok. --- Quote Start --- Remember: The MSI-X Table layout specifies for Message Address bits 01:00: «For proper DWORD alignment, software must always write zeroes to these two bits; otherwise the result is undefined. The state of these bits after reset must be 0. These bits are permitted to be read only or read/write.» --- Quote End --- Yes.
