11 years agoModular SGDMA - Streaming to Memory Mapped Random first write.
I am using the Modular SGDMA to write memory into DDR3 memory, and then a second one to read it back out again. The reading is all working fine and writing into the memory works as well, except there is one minor glitch. Basically when I issue a descriptor to write a given number of symbols to, say, address 0 (the burst length is 16 and I'm using a 512bit wide data bus). Then, Symbol 0 arrives via Avalon-ST. It immediately gets written by the SGDMA to address 0xFFFFFFFF. The next arrives and it gets queued up in the FIFO. Once symbol 16 arrives, there is a burst write of 16 symbols to address 0x0. Essentially this means the first symbol to arrive for any descriptor appears to get written to 0xFFFFFFFF, and then the remaining symbols get written to memory one address earlier than they should, thus the first symbol is lost and the rest are shifted from where they should be. Any thoughts on why this is happenning? Thanks. EDIT: I'm using a Stratix V DSP board and Quartus 14 Subscription Edition, have SignalTap set up to look at important parts of the SGDMA controller and data input. Also the design meets timing comfortably.
