11 years agoModular SGDMA - Streaming to Memory Mapped Random first write.
Hi, I am using the Modular SGDMA to write memory into DDR3 memory, and then a second one to read it back out again. The reading is all working fine and writing into the memory works as well, ex...
11 years agoInterestingly, despite the fact I have the 'Length' parameter set to 512MB, Quartus synthesizes away bits [31:16] of the length signal in the descriptor FIFOs.
EDIT: QSys for some reason put a length signal width of 16 in the generated source file instead of 30. I've tried regenerating the QSys system, but each time it sets the 'LENGTH_WIDTH' parameter on the write_master to 16?!? Is this a glitch in QSys?
