LVDS Output of FPGA
Thank you. I will try the two knobs. Apart from pre-emphasis and VOD, what other knobs are available for LVDS TX? I was thinking the following.
slew rate, current strength, weak pull up? any of these?
Hi AqidAyman_Altera ,
I see an option to tweak I/O delay. This will be very useful for me. my FPGA OPN is 10AX066N2F40E1HG. I am trying to find which setting from the following table applies to my FPGA, and it's confusing.
Does my FPGA LVDS serdes I/O belong to slow model (E1H) highlighted part? or Fast Model Extended?
- AqidAyman_Altera2 months ago
It depends on your design. You can refer to both. Both models refer to process corner models used in timing analysis which the slow model represents worst-case process/voltage/temperature and the fast model represents best-case.
These are not encoded in the OPN suffix directly; they are timing analysis corners applied to your speed grade.
Reference: https://docs.altera.com/r/docs/683243/25.3/quartus-prime-pro-edition-user-guide-timing-analyzer/multicorner-timing-analysis
