How to use Nios ↔ Logic (Avalon mm Burst Transfer)
i wanna Burst Transfer or Steamming data communication Between Logic and NIOS.
now i tried Simple Avalon mm transfer but lots of Overhead.
Addrss
Read_Data, Write_Data
Write, Read
- ShengN_altera
Links below probably can help you out:
http://www.cs.columbia.edu/~sedwards/classes/2008/4840/mnl_avalon_spec.pdf (page 72)
https://chowdera.com/2020/11/20201113203338313n.html
Video links:
https://www.youtube.com/watch?v=8GAqT3nzHeQ
https://www.youtube.com/watch?v=XTwPisYVyGg
Sheng
- ShengN_altera
May I know any further update or consideration?
Sheng
- jjang
i just finish read Avalon mm Interface Spec Sheet . and i tried to make it.
1. I Dened like that Nios..
2. Nios Connection
when Connection Initial Nios Core Settings don't have Burst Count [32] so i tried to make it
- nios → Caches and Memory Interfaces → Data Cache → Add Burstcount signal to data_master → Enable
- Avalon MM -Slave <----> NIOS Core Data Master
: Burst_Count [32] <-----> : none
: ReadDataValid [1] <-----> : ReadDataValid [1]
: Addr [8] <----> : Addr [14]
: Read [1] <----> : Read [1]
: Read_Data[32] <----> : Read_Data[32]
: wait_Request [1] <----> : wait_Request [1]
: write [1] <----->: write [1]
: Write_Data [32] <----->: Write_Data [32]
: none <-----> : Byte_Enable [4]
: none <----> : debug_mem_slave_debugaccess_to_roms [1]
for burst transfer is it good connection?
- ShengN_altera
How about the byteenable signal (Master -> Slave)?
- ShengN_altera
Since there are no further feedback for this thread, I shall set this thread to close pending. If you still need further assistance, you are welcome reopen this thread within 20days or open a new thread, some one will be right with you.
