Knug's avatar
Knug
5 years ago
How to handle properly pfl_flash_access_granted & pfl_flash_access_request signals ?
Hi @YuanLi_S_Intel
How to handle properly pfl_flash_access_granted & pfl_flash_access_request signals if PFL uses both Flash Programming + FPGA Configuration mode
Looked at the PFL doc :
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_pfl.pdf
Seen in the pin list what it describes BUT cannot get CFI_1Gb flash to be detected to perform flash programming of the generated .pof (when I combined the 2 flash programming + fpga configuration & generated just one module) within CPLD MAX V.
Seen the following message on the JTAG programmer screen:
"Waiting for pfl_flash_access_granted to be asserted"
Before we had separate loader (for flash programming) & separate config module (for FPGA configuration FPPx16) (MConfig module was a VHDL wrapper instantiating the loader_pfl) generated within the CPLD (that worked ok ie was programming the flash with the loader .pof & then autodetecting the flash & then FPGA configuration of the application code was successful) but after I combined the 2 functionalities (flash programming + FPGA configuration using FPPx16) into 1 module & tried to use same internal logic controlling the pfl_flash_access_granted & pfl_flash_access_request signals as was done for the Mconfig standalone module had problems autodetecting the flash.
The issue autodetecting the flash has to do with the controlling correctly the pfl_flash_access_granted & pfl_flash_access_request signals.
The logic that was implemented within MConfig and re-used in the 1 module (when combining the Flash Programming & FPGA Configuration together in 1 module) was:
pfl_flash_acess_request output of the loader_config_pfl was connected internally within the Loader_MConfig wrapper as follows :
pfl_flash_access_granted <= pfl_flash_access_request AND (not fpga_conf_done);
It was actually connected like this within the component instantiation :
signal r_fl_access_req : std_logic;
signal r_config_done : std_logic := '0';
pfl_inst : component config_pfl
port map (
flash_addr => flash_addr,
flash_data => flash_data,
flash_nce => flash_nce,
flash_noe => flash_noe,
flash_nwe => flash_nwe,
fpga_conf_done => fpga_conf_done,
fpga_data => fpga_data,
fpga_dclk => fpga_dclk,
fpga_nconfig => fpga_nconfig,
fpga_nstatus => fpga_nstatus,
fpga_pgm => fpga_pgm,
pfl_clk => in_clk,
pfl_flash_access_granted => r_fl_access_req and (not fpga_conf_done),
pfl_flash_access_request => r_fl_access_req,
pfl_nreset => (not r_config_done)
If I connect directly the pfl_flash_access_request output signal to the input pfl_flash_access_granted of the pfl within the Loader_MConfig wrapper, I see that I can autodetect the flash after I load the loadware code and do a power cycle BUT it fails to program the loaded application code !
I read in the above pfl doc pg13 the following :
"When programming the configuration flash memory device through the CPLD JTAG pins, you must tri-state the FPGA configuration pins common to the CPLD and the configuration flash memory device.
You can use the pfl_flash_access_request and pfl_flash_access_granted signals of the PFL block to tri-state the correct FPGA configuration pins"
pfl_flash_access_granted signal (wrt PFL IP core doc) it states that it enables the access to the flash memory device whenever the PFL IP core receives a high input signal at this pin. This active high pin can be connected permanedly high if we want PFL Core to function as the Flash Master. Pulling the pfl_flash_access_granted pin low prevents the JTAG interface from accessing the flash and FPGA configuration.
Q/ Is it ok to connect pfl_flash_access_granted input pfl to '1' and leave the pfl_flash_access_request output unconnected?
When I did this & compiled the code, I had the following extra warnings :
Warning (13044): Always-enabled tri-state buffer(s) removed
Warning (13045): Converted the fanout from the always-enabled tri-state buffer "loader_config_pfl:pfl_inst|altera_parallel_flash_loader:parallel_flash_loader_0|altparallel_flash_loader:altparallel_flash_loader_component|alt_pfl:\PFL_CFI:pfl_cfi_inst|flash_addr[0]" to the node "flash_addr[0]" into a wire
Warning (13045): Converted the fanout from the always-enabled tri-state buffer "loader_config_pfl:pfl_inst|altera_parallel_flash_loader:parallel_flash_loader_0|altparallel_flash_loader:altparallel_flash_loader_component|alt_pfl:\PFL_CFI:pfl_cfi_inst|flash_addr[1]" to the node "flash_addr[1]" into a wire
Warning (13045): Converted the fanout from the always-enabled tri-state buffer "loader_config_pfl:pfl_inst|altera_parallel_flash_loader:parallel_flash_loader_0|altparallel_flash_loader:altparallel_flash_loader_component|alt_pfl:\PFL_CFI:pfl_cfi_inst|flash_addr[23]" to the node "flash_addr[23]" into a wire
Warning (13045): Converted the fanout from the always-enabled tri-state buffer "loader_config_pfl:pfl_inst|altera_parallel_flash_loader:parallel_flash_loader_0|altparallel_flash_loader:altparallel_flash_loader_component|alt_pfl:\PFL_CFI:pfl_cfi_inst|flash_addr[24]" to the node "flash_addr[24]" into a wire
Warning (13045): Converted the fanout from the always-enabled tri-state buffer "loader_config_pfl:pfl_inst|altera_parallel_flash_loader:parallel_flash_loader_0|altparallel_flash_loader:altparallel_flash_loader_component|alt_pfl:\PFL_CFI:pfl_cfi_inst|flash_addr[25]" to the node "flash_addr[25]" into a wire
Warning (13045): Converted the fanout from the always-enabled tri-state buffer "loader_config_pfl:pfl_inst|altera_parallel_flash_loader:parallel_flash_loader_0|altparallel_flash_loader:altparallel_flash_loader_component|alt_pfl:\PFL_CFI:pfl_cfi_inst|flash_nce" to the node "flash_nce" into a wire
Warning (13045): Converted the fanout from the always-enabled tri-state buffer "loader_config_pfl:pfl_inst|altera_parallel_flash_loader:parallel_flash_loader_0|altparallel_flash_loader:altparallel_flash_loader_component|alt_pfl:\PFL_CFI:pfl_cfi_inst|flash_noe" to the node "flash_noe" into a wire
Warning (13045): Converted the fanout from the always-enabled tri-state buffer "loader_config_pfl:pfl_inst|altera_parallel_flash_loader:parallel_flash_loader_0|altparallel_flash_loader:altparallel_flash_loader_component|alt_pfl:\PFL_CFI:pfl_cfi_inst|flash_nwe" to the node "flash_nwe" into a wire
I did not attempt to try this on the bench yet. Asking whether it is ok to try this but seen above (13045) warning Converted the fanout from the always-enabled tri-state buffer to a wire !!
Any help on this matter will be appreciated
Kevin
