How to handle properly pfl_flash_access_granted & pfl_flash_access_request signals ?
Four our dev kit design, we just connect "pfl_flash_access_granted" to "pfl_flash_access_request" as we are just using Quartus Programmer to program the flash.
- JohnT_Altera5 years ago
Attach is the reference design
- Knug5 years ago
Contributor
Hi @JohnT_Intel
Just looked at the latest kit you sent me.
We are not using the following PFL pins :
flash_clk
flash_nadv
flash_nresetAre you using burst mode? Burst mode requires flash_clk, flash_nadv & flash_rdy. We are not using burst mode. If you are using burst mode. How do you enable it?
Q/ Do I need to enable the flash_nreset (out) of the PFL and connect it directly to the input of the flash? Will this help resolve the issue ?
Noticed as you said that you just connect the pfl_flash_access_request to the pfl_flash_access_granted signal. Tried that already few times and it crashed ie flash could not be autodetected.
The pfl_nreset you just connect to the top input reset pin.
Tried this pfl_nreset option too ie connected it to the top level and pfl_flash_access_request to connected to the pfl_flash_access_granted signal. It autodetects the flash after I programmed/configured the PFL loadware and powered cycled. But then when I tried to program the Application code to the flash it failed to program it !
- Knug5 years ago
Contributor
Hi @JohnT_Intel
Looking at the max5 kit once more you sent me last time & wondering how this worked for you if the .qsf does not list the slow_clk_gen.vhd file which it was instantiated by the max5.vhd ?
The other thing I noticed from the simpler kit was that the .qsf listed also many of other pins that the max5 top level did not listed as ports (those ports looked to belong to the complex kit one)
& also noticed that the pfl_clk is clocked by external 100MHz (clk_config) (constraints file defined 10ns) compared to the clkin_max_50 (50MHz) main input clk.
I just have 1 clock input to the PFL and it is set to 10MHz. Does the pfl_clk need to be overclocked?
The 2 separate PFLs worked with the 10MHz main clock.
Also I noticed that the slow_clk_gen module not all outputs are used :
Warning (10036): *** object "clk_pls_n" assigned a value but never read
Warning (10036): *** object "clk_pls_p_deley" assigned a value but never read
Warning (10036): *** object "slow_clk" assigned a value but never readJust the clk_pls_p one !
& after I run the above similar to what kit was doing (included the slow_clk_gen module & kept my 1 clk @ 10MHz), it was worse than before ie it failed to program the flash "Can't recognize silicon ID for Device 1. Operation Failed"
Kevin
