How to handle properly pfl_flash_access_granted & pfl_flash_access_request signals ?
May I know if you have tried to refer to the board update portal design where it is part of the development kit installation file?
Hi @JohnT_Intel
I don't understand your question here.
Which board update portal design (part of the development kit installation file) do you mean ?
I instantiated the PFL with both "Flash Programming and FPGA Configuration" options enabled together and had the same setups as the separate standalone PFLs done before (before we had 2 separate PFLs with not both options mixed up together, that worked) and having intermittent issues with the combined 1 PFL solution accessing the flash to be able to Program it.
My suspicion it may have to do with the control of the pfl_flash_access_granted / pfl_flash_access_request signals.
I did not get a satisfactory reply to my query yet.
Is there a reference document or a reference kit link that describes the way to setup the combined "Flash Programming and FPGA Configuration" to 1 PFL solution?
Kevin
- Knug5 years ago
Contributor
Still waiting for a satisfactory reply. Cannot proceed without resolving this issue ..
