HDMI Intel FPGA IP as Receive with AXIS fails in Analysis & Synthesis of Quartus 24.3 Pro
Hi support,
When creating a design with "HDMI Intel FPGA IP" having significant values as:
- Direction: Receiver
- Enable Active Video Protocol: AXIS-VVP Full
- Support FRL: Untick (disabled)
Then Quartus 24.3 Pro Build 212 (newest) fails in Analysis & Synthesis with the errors:
Error(13224): Verilog HDL or VHDL error at hdmi_rx_core_altera_hdmi_1975_ozylggi.v(771): index 2 is out of range [1:0] for 'cv_vid_de'
Error: Failed to elaborate design:
Error: Flow failed: Errors generated during elaboration
Error: Quartus Prime Synthesis was unsuccessful. 3 errors, 0 warnings
Archived project is attached.
Question: Is there any known fix or workaround for this problem?
M_DK_FPGA
PS. It appears that an internal non-designer assigned value PIXELS_PER_CLOCK is assigned to 8, as for FRL enabled, thus causing an internal loop to go out of range.
Hi @M_DK_FPGA ,
I understand your reason to turn off the "support Aux" and "deep colour" with reason to support your custom 24 bit pixel data.
However , turning OFF support Aux and deep colour will make the output in-stable (blank most of the time).
Also, This will only save minor logic utilization. That why we make those two as default to suit most of the use cases.Currently AXI Bridge is setting to 16BPS (16x3 48bits).
If fewer bits are requires, you just need to pad the LSB without disable the AUX and Deep Colour.
Detail about the implementation you may refer to- HDMI user guide 5.1.19. AXI4-Stream to Clocked Video Converter (AXI2CV)
- Intel AXI Streaming Video Protocol Specification: 2.2.10. Packing RGB444 onto an RGB888 Interface
Hope that able to help you to move a step forward, let me know if further clarification is needed.
Wincent_Altera
- M_DK_FPGA
Hi Wincent_Altera,
Thanks for the project file .qar.
I unpacked the files, and looked at the HDMI IP Rx and Tx cores.
Searching for VIDEO_PROTOCOL shows that the setting is "none" for clocked video, and not "vvp_full" for "AXIS-VVP Full"; relevant files are:
- ^/hdmi_0_example_design/rtl/hdmi_rx/hdmi_rx/hdmi_rx.html and .xml
- ^/hdmi_0_example_design/rtl/hdmi_tx/hdmi_tx/hdmi_tx.html and .xml
The design also shows it, since the HDMI IP Rx and Tx PHYs are not used as would require AXIS-VVP Full, but the transceivers for HDMI are made using GXB blocks directly.
May I suggest that you take a look at the original question from December 15 2024, and try to generate the HDMI Core with:
- Support FRL: Untick (disabled)The generated design is also attached as a file .qar with the original question.
Simply by code inspection of the generated hdmi_rx_core_altera_hdmi_1975_ozylggi.v file, it is possible to see that there is problem with the design.
The module hdmi_rx_core_altera_hdmi_1975_ozylggi is used in file hdmi_rx_core.vhd at lines 192 forward through a component with configuration as:
hdmi_0 : component hdmi_rx_core_altera_hdmi_1975_ozylggi_cmp
generic map (
FAMILY => "Arria 10",
SYMBOLS_PER_CLOCK => 2,
PIXELS_PER_CLOCK => 8,
The module in file hdmi_rx_core_altera_hdmi_1975_ozylggi.v has code:
wire [SYMBOLS_PER_CLOCK - 1 : 0] cv_vid_de;
for (p=0; p<PIXELS_PER_CLOCK; p=p+1) begin: vid_data_p
if(cv_vid_de[p] && (vid_valid == 1'b1)) begin
...So loop variable p is in range 0 to PIXELS_PER_CLOCK - 1 = 8 - 1 = 7, but wire cv_vid_de is only defined with range 0 to SYMBOLS_PER_CLOCK - 1 = 2 - 1 = 1.
During synthesis, Quartus tries to access p[2], that is out of range, thus giving the error meassage:
Error(13224): Verilog HDL or VHDL error at hdmi_rx_core_altera_hdmi_1975_ozylggi.v(771): index 2 is out of range [1:0] for 'cv_vid_de'This problem can be confirmed by code inspection, thus without any pin placement or other synthesis.
Have you tried to recreate the original problem that I reported, showing the above problem in the code ?
M_DK_FPGA- Wincent_Altera
Hi @M_DK_FPGA ,
I follow your setup , and the compilation passing 100 % and I did not observed any synthesis error...
Attach the .qar file in the attachment.If this still did not address your question, I would suggest to have a Teams Call meeting.
It would help me better understand the challenge that you are seeing now, My time zone will be GMT +8.
Let me know your convenience time and email address, will sent the meeting invitation upon your agreement.
Regards,Wincent_Altera
- M_DK_FPGA
Hi Wincent_Altera,
The HDMI Rx IP shows that the Video Protocol is None, as you can seen in the attached image.
May I suggest that you try to unpack the qar file you attached, and check the actual IP setting.
You can also just search for VIDEO_PROTOCOL in the files, where you in file ^/devkit2/hdmi_0_example_design/rtl/hdmi_rx/hdmi_rx/hdmi_rx.xml will find <parameter name="VIDEO_PROTOCOL" value="none" />.
Please also take a look at the originally generated code, where I in my previous answer described the mismatch between config parameters PIXELS_PER_CLOCK and SYMBOLS_PER_CLOCK.
Also you could try just to run the synthesis of the originally attached qar file, which will shown the problem.
That should be straight forward to do.
Thanks for the offer for a Teams Call
For now I think we have enough technical issues to resolve, so until the above is addressed I would not think a Teams Call is required.
Using HDMI PHY Intel FPGA IP Design example, it enable the AXIS-VVP-FULL by default.
As per mentioned by Rong Yuan in the past reply.Next will try to disable AUX and deep color and see if I am able to replicate your issue or not.
- Wincent_Altera
Hi @M_DK_FPGA ,
Sorry forget to update you, try to disable AUX and deep color the AXIS-VVP full by default disable again in new generated HDL.
I might need more time to check on this (around 7-14 days).
Will update you back ASAP.
Wincent_Altera
