15 years agoHDL-master for SDRAM controller
I'm trying to connect my own hdl-master with DDR SDRAM Controller (MegaCore) for writing in off-chip memory. This UG (http://www.altera.com/literature/ug/ug_ddr_sdram.pdf) doesn't contain any information about basic avalon signals (write,writedata and etc.). How I must to control this signals in my master? How the address space is allocated in controller? For example, I attempted to write word of data in base controller address (without any offset) but it doesn't produce the expected result. Thanks for any help.2 Replies
The avalon specification is here (http://www.altera.com/literature/manual/mnl_avalon_spec.pdf).
Writing to the base address should work. Just remember that on an avalon master interface, the address is byte aligned, and not word aligned like on a slave interface. - Altera_Forum
Somewhere in this tutorial .zip file are a bunch of components written for Qsys (and SOPC Builder), two of which are read and write masters. They should give you a good idea how to structure your logic: http://www.altera.com/support/examples/design-entry-tools/qsys/exm-qsys-tut.html (http://www.altera.com/support/examples/design-entry-tools/qsys/exm-qsys-tut.html?)
