10 years agoGenerate HDL in QSYS with DSP builder block fails
Hi
I am currently trying to generate HDL in the Qaurtus Prime QSYS version 15.1.0.189. I have succesfull imported the dspbuilder block by adding the path and connecting the DSP builder block in the hps_qsys system. But when I am trying the generate the HDL, the generator keeps giving me some errors which halts the process. The errors are: Error: invalid command name "quartus_synth_callback"while executing "quartus_synth_callback PfcCurReg_dut" Info: PfcCurReg_dut_0: "hps_qsys" instantiated PfcCurReg_dut "PfcCurReg_dut_0" Error: Generation stopped, 33 or more modules remaining Info: hps_qsys: Done "hps_qsys" with 20 modules, 3 files Error: qsys-generate failed with exit code 1: 2 Errors, 2 Warnings Info: Finished: Create HDL design files for synthesis Are am missing something crucial to the implemtation of the DSP builder block? Please advice? Best regards Kim1 Reply
- Ghe0rghe
I too am having the same problem:
It seems like I can successfully import DSPBuilder-generated IP cores into Qsys using their hw.tcl file and .vhd files, but for some reason they do not compile in Qsys, where I receive the same error as you: "invalid command name "quartus_synth_callback""
Best,
-Gheorghe
