10 years agoGenerate HDL in QSYS with DSP builder block fails
Hi I am currently trying to generate HDL in the Qaurtus Prime QSYS version 15.1.0.189. I have succesfull imported the dspbuilder block by adding the path and connecting the DSP builder block i...
Ghe0rghe
5 years agoI too am having the same problem:
It seems like I can successfully import DSPBuilder-generated IP cores into Qsys using their hw.tcl file and .vhd files, but for some reason they do not compile in Qsys, where I receive the same error as you: "invalid command name "quartus_synth_callback""
Best,
-Gheorghe
