16 years agoGate level simulation in ModelSim with DSP Builder generated designs
I try to further verify my design in DSP-Builder by applying gate-level simulation in Altera-ModelSim. But some modules which have no problems in RTL simulation do not work in the port-synthesis and gate-level simulation. I will try to describe my problems and would be grateful if someone could give some hints about how to fix it.
For instance, I have setup a counter in my DSP-Builder and can run the Simulink and rtl simulation on ModelSim without any problems. And then I run the full compilation in Quartus II to generate the vho and sdf files for post-synthesis and gate-level simulation in ModelSim. To do so, I also compile the altera_primitives_component.vhd into the altera library directory in ModelSim, so that I can compile the vho file into the work library. But then I get some warning messages when I run the post-synthesis simulation: ** Warning: (vsim-3473) Component instance "\auto_inst|adder_FPGA_0|Counter|Counteri|auto_generated|counter_reg_bit[1]\ : dffeas" is not bound. # Time: 0 ps Iteration: 0 Region: /tb_adder/dut File: C:/Work/Matlab/adder/tb_adder/simulation/modelsim/adder.vho # ** Warning: (vsim-3473) Component instance "\auto_inst|adder_FPGA_0|Counter|Counteri|auto_generated|counter_reg_bit[2]\ : dffeas" is not bound. # Time: 0 ps Iteration: 0 Region: /tb_adder/dut File: C:/Work/Matlab/adder/tb_adder/simulation/modelsim/adder.vho # ** Warning: (vsim-3473) Component instance "\auto_inst|adder_FPGA_0|Counter|Counteri|auto_generated|counter_reg_bit[3]\ : dffeas" is not bound. # Time: 0 ps Iteration: 0 Region: /tb_adder/dut File: C:/Work/Matlab/adder/tb_adder/simulation/modelsim/adder.vho # ** Warning: (vsim-3473) Component instance "\auto_inst|adder_FPGA_0|Counter|Counteri|auto_generated|counter_reg_bit[4]\ : dffeas" is not bound. # Time: 0 ps Iteration: 0 Region: /tb_adder/dut File: C:/Work/Matlab/adder/tb_adder/simulation/modelsim/adder.vho # ** Warning: (vsim-3473) Component instance "\auto_inst|adder_FPGA_0|Counter|Counteri|auto_generated|counter_reg_bit[5]\ : dffeas" is not bound. # Time: 0 ps Iteration: 0 Region: /tb_adder/dut File: C:/Work/Matlab/adder/tb_adder/simulation/modelsim/adder.vho And my counter output become "UUUUUU". When I try to run a gate-level simulation by further taking the sdf file into the simulation. Then I get the following error messages: ( my counter out is 8 bit, I get error for each bit port, but some messages are omitted here due to their similarities) ... # ** Warning: (vsim-SDF-3250) C:/Work/Matlab/adder/tb_adder/simulation/modelsim/adder_vhd.sdo(1054): Failed to find INSTANCE '\auto_inst|adder_FPGA_0|Counter|Counteri|auto_generated|counter_reg_bit[5]\'. # ** Warning: (vsim-SDF-3250) C:/Work/Matlab/adder/tb_adder/simulation/modelsim/adder_vhd.sdo(1089): Failed to find INSTANCE '\auto_inst|adder_FPGA_0|Counter|Counteri|auto_generated|counter_reg_bit[6]\'. # ** Warning: (vsim-SDF-3250) C:/Work/Matlab/adder/tb_adder/simulation/modelsim/adder_vhd.sdo(1124): Failed to find INSTANCE '\auto_inst|adder_FPGA_0|Counter|Counteri|auto_generated|counter_reg_bit[7]\'. # ** Warning: (vsim-SDF-3894) : Errors occured in reading and resolving instances from compiled SDF file(s). My questions are: What is my problem here, did I forget something? It seems that modelsim have problem with "dffeas". But what is it? How should I integrate my DSP-Builder design into my top-level design in Quartus II? Now I use the "export" option of the DSP-Builder Signal Compiler to export the vhdl files to my project and then instantiate my DSP-Builder design. But many modules seem not to be working in the post-synthesis or gate-level simulation , although everything is fine in rtl level simulation. Many thanks for your helps! Yang3 Replies
you shouldn't have to compile any libraries when using ModelSim-AE.
i'm not sure what the problem is but i recommend trying to simulate using the NativeLink flow which usually does a good job setting up the simulation: http://www.altera.com/literature/hb/qts/qts_qii53001.pdf - Altera_Forum
Well, the problem is, the automatically generated tcl files does not compile the altera_primitives_components.vhd into the altera library, which is needed for the compilation of the vho file. So I just added this step to get the thing work.
As far as I know, NativeLink is not so flexible as using ModelSim directly. And I could not image if something does not work in ModelSim-AE will work with NativeLink. Or you could provide me more details about the advantages of using NativeLink? Thank you! - Altera_Forum
from my previous link:
--- Quote Start --- In the ModelSim-Altera software, the pre-compiled libraries for both functional and gate-level simulations are available. You do not have to explicitly compile these library files before running the simulation directly. --- Quote End --- i agree that NativeLink is not as flexible as using ModelSim or writing your own simulation script, but i often use NativeLink to generate the initial .do file and edit it to taste so i don't have to do the tedious work. :)
