16 years agoGate level simulation in ModelSim with DSP Builder generated designs
I try to further verify my design in DSP-Builder by applying gate-level simulation in Altera-ModelSim. But some modules which have no problems in RTL simulation do not work in the port-synthesis and ...
16 years agoWell, the problem is, the automatically generated tcl files does not compile the altera_primitives_components.vhd into the altera library, which is needed for the compilation of the vho file. So I just added this step to get the thing work.
As far as I know, NativeLink is not so flexible as using ModelSim directly. And I could not image if something does not work in ModelSim-AE will work with NativeLink. Or you could provide me more details about the advantages of using NativeLink? Thank you!
