SERMASWATHIKA's avatar
SERMASWATHIKA
2 years ago
facing 12002 error while upgrading qsys design from 13.0 to 22.1 quartus
Hi Team,
i have upgrading the qsys design from 13.0 to 22.1 . during upgradation, added ddr3 ip and generated the qsys.
while synthesizing the design , facing 12002 error. whether do i miss any steps in qsys?
i am new to qsys design and please help me to resolve this issue? Attached the screenshot of error.
  • sstrell's avatar
    sstrell
    For such a huge jump in versions, you probably still have old components in the system no longer supported in the newer version and that can't be updated automatically. If so, you need to delete and then re-add and parameterize the new versions of the components.
  • ShengN_altera's avatar
    ShengN_altera
    Yes, from 13.0 to 22.1 there'll be much old components which are EOL and need replacement.
    Sheng
    ShengN_altera
    Do you have any further concern or consideration from your side?
    Sheng
  • i have removed submodules directory 13.0 version still i am facing this error.
    ShengN_altera
    You may need to remove from Project Navigator in GUI as well. Then replace with a new IP.
    Sheng
    • SERMASWATHIKA's avatar
      SERMASWATHIKA
      when i tried to update top bdf file i am getting the following error. and quartus tool closed abruptly.
      Problem Details
      Error:
      *** Fatal Error: Uncaught C++ Exception
      Module: quartus.exe
      Stack Trace:
          0x2cf18: RaiseException + 0x68 (KERNELBASE)
           0x4461: _CxxThrowException + 0xc1 (VCRUNTIME140)
           0x6bf5: boost::filesystem::detail::recur_dir_itr_imp::increment + 0xd5 (boost_filesystem-mt-x64)
          0x1306b: boost::filesystem::recursive_directory_iterator::increment + 0x5b (CCL_FIO)
          0x101d5: FIO_FIND::add_subdirs + 0x4d5 (CCL_FIO)
          0x134cf: FIO_FIND::init + 0x3ef (CCL_FIO)
          0xc6ee6: GEDQ_VIEW::symbol_file_exists + 0x1a6 (edt_gedq)
          0xb0d19: GEDQ_UPDATE_SYMBOL_COMMAND::update_symbol_or_block + 0x199 (edt_gedq)
          0xae1d5: GEDQ_UPDATE_SYMBOL_COMMAND::create_update_command + 0x2d5 (edt_gedq)
          0xae434: GEDQ_UPDATE_SYMBOL_COMMAND::execute + 0x24 (edt_gedq)
          0x54ad4: GEDQ_FRAME_WND::execute_command + 0x44 (edt_gedq)
          0xc417a: GEDQ_VIEW::on_update_symbol_action + 0x8a (edt_gedq)
         0x1fb37f: QMimeData::urls + 0x13bf (Qt5Core)
           0x6c96: QAction::activate + 0x136 (Qt5Widgets)
         0x161d17: QMenu::actionGeometry + 0x457 (Qt5Widgets)
         0x161b85: QMenu::actionGeometry + 0x2c5 (Qt5Widgets)
         0x167298: QMenu::mouseReleaseEvent + 0xb8 (Qt5Widgets)
          0x397d5: QWidget::event + 0x145 (Qt5Widgets)
         0x16348b: QMenu::event + 0x17b (Qt5Widgets)
          0x1737c: QApplicationPrivate::notify_helper + 0x13c (Qt5Widgets)
          0x15080: QApplication::notify + 0x7d0 (Qt5Widgets)
         0x1dae38: QCoreApplication::notifyInternal2 + 0xb8 (Qt5Core)
          0x186e1: QApplicationPrivate::sendMouseEvent + 0x331 (Qt5Widgets)
          0x618cd: QSizePolicy::QSizePolicy + 0x278d (Qt5Widgets)
          0x5fb26: QSizePolicy::QSizePolicy + 0x9e6 (Qt5Widgets)
          0x1531e: QApplication::notify + 0xa6e (Qt5Widgets)
          0x5bf63: QGuiApplicationPrivate::processMouseEvent + 0x723 (Qt5Gui)
          0x4726a: QWindowSystemInterface::sendWindowSystemEvents + 0x9a (Qt5Gui)
         0x22835d: QEventDispatcherWin32::processEvents + 0xbd (Qt5Core)
          0x5a4e8: qt_plugin_query_metadata + 0x1dc8 (qwindows)
         0x1d6c60: QEventLoop::exec + 0x1a0 (Qt5Core)
         0x1639c7: QMenu::exec + 0x1c7 (Qt5Widgets)
         0x1637ba: QMenu::exec + 0x1a (Qt5Widgets)
          0xb4da2: GEDQ_VIEW::contextMenuEvent + 0x2d2 (edt_gedq)
          0x39dc4: QWidget::event + 0x734 (Qt5Widgets)
          0x158b6: QApplication::notify + 0x1006 (Qt5Widgets)
          0x62137: QSizePolicy::QSizePolicy + 0x2ff7 (Qt5Widgets)
         0x1d9b2a: QCoreApplication::exec + 0x14a (Qt5Core)
           0x10bb: qgq_main + 0x8b (quartus)
          0x13538: msg_main_thread + 0x18 (CCL_MSG)
          0x1484e: msg_thread_wrapper + 0x6e (CCL_MSG)
          0x18210: mem_thread_wrapper + 0x70 (ccl_mem)
          0x12cf1: msg_exe_main + 0xa1 (CCL_MSG)
           0x20c6: WinMain + 0x156 (quartus)
           0x16d2: __scrt_common_main_seh + 0x116 (quartus)
          0x17343: BaseThreadInitThunk + 0x13 (KERNEL32)
          0x526b0: RtlUserThreadStart + 0x20 (ntdll)
      End-trace
      Executable: quartus
      Comment:
      None
      System Information
      Platform: windows64
      OS name: Windows 10
      OS version: 10.0
      Quartus Prime Information
      Address bits: 64
      Version: 22.1std.2
      Build: 922
      Edition: Standard Edition
    ShengN_altera
    Possible to provide that .bdf for testing out?
    Sheng
      SERMASWATHIKA
      i tried to add the bdf file in attachment, bdf format is not supported in attachment. i am migrating the design from cyclone III device to cyclone v gx and ddr2 to ddr3.
      So i have removed the ddr2 ip and added the ddr3 ip in qsys system and generated the qsys file without errors.
      but in bdf file i could not update the port signal names which are for ddr2.. while updating for that( click the update and symbol block option) i am facing the above quartsu error and project window closed abruptly.
    ShengN_altera
    Since ddr2 ip had been replaced with ddr3 ip, you should see .bsf file being generated when generating ddr3 ip. In bdf, probably need to manually remove the ddr2 and insert the ddr3 block symbol.
    Btw you can provide the .bdf file in zip format.
    Sheng
    ShengN_altera
    I had done checking the bdf file. In bdf, that's the qsys system .bsf.
    When generating qsys system, tick the Create block symbol file (.bsf), should see qsys system bsf being generated.
    Sheng
      SERMASWATHIKA
      i have opted for bsf file option while generating the qsys. But the thing is updated bsf file is not reflecting in bdf file . if we tried update also tool is closing.
      Now i have deleted the symbol and added new symbol in bdf file. analysis is going through.
    ShengN_altera
    Yes, have to replace the block symbol (.bsf) in bdf file with a new one since you have changed the ddr2 ip to ddr3 ip.
    Simply update the .bsf file wouldn't work.
    Sheng
    ShengN_altera
    Do you have any further concern or consideration?
    Sheng
