SERMASWATHIKA
Contributor
2 years agofacing 12002 error while upgrading qsys design from 13.0 to 22.1 quartus
Hi Team, i have upgrading the qsys design from 13.0 to 22.1 . during upgradation, added ddr3 ip and generated the qsys. while synthesizing the design , facing 12002 error. whether do i miss an...
ShengN_altera
2 years agoHi,
Since ddr2 ip had been replaced with ddr3 ip, you should see .bsf file being generated when generating ddr3 ip. In bdf, probably need to manually remove the ddr2 and insert the ddr3 block symbol.
Btw you can provide the .bdf file in zip format.
Sheng
SERMASWATHIKA
Contributor
2 years agook i will try that. i have attached bdf file in this message
