F-Tile PMA/FEC Direct PHY Multirate IP
Required help in simulation of 400G-8 F-tile multirate dynamic reconfig IP example design.
I have run the simulation of the generated example design for the 400G-8 multirate F-tile dynamic reconfig IP. I was expecting the initial profile switching from the default to other as given in example design and we wiil be expecting "dr_in_progress" signal to go low once profile switching is completed properly. The signal is NOT GOING LOW for me and the simulation is also taking more than 4 hours to reach 1ms in the sim better if run faster. And I have also tried the simulation of 50G-1 F-tile multirate dynamic reconfig IP example design and there the signal is GOING LOW properly after each profile switch. below are few screenshots of questa sim simulation of the 400G-8 examle design trying to go from profile id 1(default) to profile id 2. csr clk is 100MHz and cpu clk is 100MHz and 100GHz based on the 'dr_fast_sim_clk_sel' signal out(1- high freq; 0- low freq)
- Jagadeesh_engineer
New Member
I have run the simulation from 26.1 version of questa simens tool and 26.1 quartus for the synthesis and sim scripts generations
- ai_responder
Community Manager
Thank you for your inquiry. To ensure an accurate response, your request has been routed to an Altera application engineer for further review and assistance.
Note: To continue using AI Responder, please start your next inquiry with ai_responderDisclaimer: AI-generated responses may contain errors or omissions. Please verify technical guidance with official Altera documentation before implementation.
Thank you very much.
