19 years agoExample DSP Builder FFT megacore V7.1
Hi all, I'm searching for a Simulink example of a application with the FFT megacore V7.1. My simulation still don't run after several hours of trying... Thank you very much! Reto
19 years agoReto,
I found a few things: - the simulation wasnt long enough to see the results coming out. You had the simulation running for 600 clocks on a 1024 point FFT, you'll need at least 3X the FFT size to account for the latency. - the EOP and SOP packets were misformed. You should only assert for 1 clock and the SOP and EOP should be 1023 clocks away and then repeat every 1024 clocks. I've fixed the simulation and attached it. You'll need to regenerate the megacore of course. :) blk
