Error(14530): pce_tx[0] is locked to a non-HIP location. The HIP locations are G22 G22 G22 G22 G22
I tried to move the project from 10cx220YF780E5G to 10CX220YU484I5G.
Bank Pair Bank Pair
pce_rx[0] Input PIN_V26 1C pce_rx[0](n) PIN_V26 PIN_Y20 1C pce_rx[0](n)
pce_rx[0](n) Input 1C pce_rx[0] PIN_V25 PIN_Y19 1C pce_rx[0]
pce_rx[1] Input PIN_T26 1C pce_rx[1](n) PIN_T26 PIN_U22 1C pce_rx[1](n)
pce_rx[1](n) Input 1C pce_rx[1] PIN_T25 PIN_U21 1C pce_rx[1]
pce_rx[2] Input PIN_P26 1D pce_rx[2](n) PIN_P26 PIN_N22 1C pce_rx[2](n)
pce_rx[2](n) Input 1D pce_rx[2] PIN_P25 PIN_N21 1C pce_rx[2]
pce_rx[3] Input PIN_M26 1D pce_rx[3](n) PIN_M26 PIN_J22 1C pce_rx[3](n)
pce_rx[3](n) Input 1D pce_rx[3] PIN_M25 PIN_J21 1C pce_rx[3]
pce_tx[0] Output PIN_W28 1C pce_tx[0](n) PIN_W28 PIN_AA22 1C pce_tx[0](n)
pce_tx[0](n) Output 1C pce_tx[0] PIN_W27 PIN_AA21 1C pce_tx[0]
pce_tx[1] Output PIN_U28 1C pce_tx[1](n) PIN_U28 PIN_W22 1C pce_tx[1](n)
pce_tx[1](n) Output 1C pce_tx[1] PIN_U27 PIN_W21 1C pce_tx[1]
pce_tx[2] Output PIN_R28 1D pce_tx[2](n) PIN_R28 PIN_R22 1C pce_tx[2](n)
pce_tx[2](n) Output 1D pce_tx[2] PIN_R27 PIN_R21 1C pce_tx[2]
pce_tx[3] Output PIN_N28 1D pce_tx[3](n) PIN_N28 PIN_L22 1C pce_tx[3](n)
pce_tx[3](n) Output 1D pce_tx[3] PIN_N27 PIN_L21 1C pce_tx[3]
Error(14530): pce_tx[0] is locked to a non-HIP location. The HIP locations are G22 G22 G22 G22 G22 G22.
A very strange list for selecting pins. Maybe a Quartus error?
- SengKok_L_Intel
The 10CX220YU484I5G only has 1 PCIe HIP, you may try to remove the PCIe pins assignment and let Quartus auto-assign for you, and then you can check the pin assignment location from the fitter report.
Regards -SK
- VadimK
Thank you for your responsiveness!
I removed the pin assignments:
Node Name Direction Location I/O Bank I/O standart Dif Pair pce_rx[3] Input Current Mode Logic (CML) pce_rx[3](n) pce_rx[3](n) Input Current Mode Logic (CML) pce_rx[3] pce_rx[2] Input Current Mode Logic (CML) pce_rx[2](n) pce_rx[2](n) Input Current Mode Logic (CML) pce_rx[2] pce_rx[1] Input Current Mode Logic (CML) pce_rx[1](n) pce_rx[1](n) Input Current Mode Logic (CML) pce_rx[1] pce_rx[0] Input Current Mode Logic (CML) pce_rx[0](n) pce_rx[0](n) Input Current Mode Logic (CML) pce_rx[0] pce_tx[3] Output High Speed Differential I/O pce_tx[3](n) pce_tx[3](n) Output High Speed Differential I/O pce_tx[3] pce_tx[2] Output High Speed Differential I/O pce_tx[2](n) pce_tx[2](n) Output High Speed Differential I/O pce_tx[2] pce_tx[1] Output High Speed Differential I/O pce_tx[1](n) pce_tx[1](n) Output High Speed Differential I/O pce_tx[1] pce_tx[0] Output High Speed Differential I/O pce_tx[0](n) pce_tx[0](n) Output High Speed Differential I/O pce_tx[0] pcie_perstn Input 1.8 V pcie_refclk Input Current Mode Logic (CML) pcie_refclk(n) pcie_refclk(n) Input Current Mode Logic (CML) pcie_refclk Now it gives this error:
Error(14566): The Fitter cannot place 1 periphery component(s) due to conflicts with existing constraints (1 HSSI_GEN3_X8_PCIE_HIP(s)). Fix the errors described in the submessages, and then rerun the Fitter. The Intel FPGA Knowledge Database may also contain articles with information on how to resolve this periphery placement failure. Review the errors and then visit the Knowledge Database at https://www.altera.com/support/support-resources/knowledge-base/search.html and search for this specific error message number.
Error(175001): The Fitter cannot place 1 HSSI_GEN3_X8_PCIE_HIP, which is within Intel Arria 10/Cyclone 10 Hard IP for PCI Express top_pcie_a10_hip_0_altera_pcie_a10_hip_181_nzarq7q.
Info(14596): Information about the failing component(s):
Info(175028): The HSSI_GEN3_X8_PCIE_HIP name(s): conv3x3_coprocessor_i|top_hw_i|pcie_a10_hip_0|pcie_a10_hip_0|altpcie_a10_hip_pipen1b|wys
Error(16234): No legal location could be found out of 1 considered location(s). Reasons why each location could not be used are summarized below:
Error(175006): There is no routing connectivity between the HSSI_GEN3_X8_PCIE_HIP and destination HSSI_RX_PLD_PCS_INTERFACE
Info(175027): Destination: HSSI_RX_PLD_PCS_INTERFACE conv3x3_coprocessor_i|top_hw_i|pcie_a10_hip_0|pcie_a10_hip_0|altpcie_a10_hip_pipen1b|g_xcvr.altpcie_a10_hip_pllnphy|g_xcvr.g_phy_g2x4.phy_g2x4|phy_g2x4|g_xcvr_native_insts[2].twentynm_xcvr_native_inst|twentynm_xcvr_native_inst|inst_twentynm_pcs|gen_twentynm_hssi_rx_pld_pcs_interface.inst_twentynm_hssi_rx_pld_pcs_interface
Error(175022): The HSSI_GEN3_X8_PCIE_HIP could not be placed in any location to satisfy its connectivity requirements
Error(175022): The HSSI_RX_PLD_PCS_INTERFACE could not be placed in any location to satisfy its connectivity requirements
Info(175029): 1 location affected
Info(175029): HSSIGEN3X8PCIEHIP_L0*.rpt files are not generated.
What should I do now?
- SengKok_L_Intel
I found that you are using the C10 u484 package, please refer to the notes in the product table below, this package only supports 2 lanes of PCIe. Please change your design to Gen2/1x2.
- VadimK
Thanks for the tip!
Do I understand correctly that only such connection to contacts is possible?
pce_rx[1] PIN_A20 pce_rx[0] PIN_E22 pce_rx[1](n) PIN_A19 pce_rx[0](n) PIN_E21 pce_tx[1] PIN_C22 pce_tx[0] PIN_G22 pce_tx[0](n) PIN_G21 pce_tx[1](n) PIN_C21 It turns out that it is impossible to connect tx0 to AA22?
Constantly writes: "Hip locations-G22 G22 G22 G.."
After all, we have already made a printed circuit board.
- SengKok_L_Intel
Apparently, channel 0 of PCIe is started at G22. This is the hard block, so their location is unable to change.
- VadimK
Now I understand. Thank you for your help!
- SengKok_L_Intel
If further support is needed in this thread, please post a response within 15 days. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
