16 years ago
ddr2 sdram
Hello, I'am new to SOPC build,and sorry for my poor english.
I have bought a dsp development kits from alter,and there is an ddr2 sdram on this development board.
this is the development kits I have bought:
http://www.buyaltera.com/scripts/partsearch.dll?detail&name=544-1699-nd
In my sopc build, i only add there components: niso ii cpu,jtag uart and ddr2 sdram controller megacore funtion - altera corporation
I don't know how to fill these parameters about this ddr2 sdram controller,when i generate this cpu by default setting,I found there are some files about pll(such as ddr_pll_cyclonii) are generate by system,I don't konw how to use these files.
can anyone help me,or send me a example about,thank you
[email protected]
    I think it's the way you locate the DDR2 controller on-chip and that is often used to meet some critical path requirements. Keep it as the default.
    --- Quote Start ---
    --- Quote End ---
    May I have your email?
    Thank you!
    In my project, I set "memory data width" to 64,and let all others the same
    as the "standard" project,and assign my pins following the original ddr2
    core location
    But I get this error information when I run "Hello world!"
    Verifying 10010000 ( 0%)
    Verify failed between address 0x10010000 and 0x1001001F
    Leaving target processor paused
    Thank you
    --- Quote Start ---
    something goes wrong when using the full data width for the DDR2
    [email protected]
    --- Quote End ---
    Do you raise your ddr2 sdram's memory by change "memory data bus width" or change the "chip select"?
    I found that when I set "memory data bus width" to 32,and let "chip select" to be 1, I can use 128M of the ddr2 sdram.But when I set "chip select" to be 2 or change "memory data bus width" to 64,they both don't work well.
    I found another phenomenon, quartus9 will assign "dq,dqs,dm" automatically,and you must use these automatically assigned pins,otherwise you will get a "DDIO" error when compile these project.
    First of all you can not use 2 chip select cause the DDR2 you are using doesn't support two chip select.
    Second, the automatic assignment you are talking about are pre-assigned since you are using the "standard" template.
    Finally, I am having the same problem when I am trying to increase the data width to 64-bit, it's something I cannot figure out!
    --- Quote Start ---
    --- Quote End ---
    Thank you!
    I build a new project, it only contain cput, jtag uart and ddr2 sdram, I am not using the "standard" template.but the quartus still automatic assigg the pins. If quartus didn't assign the pins automatically,and I finish the pins assigment manually, I will get an warning in "Filtter" process,the waring is something about "capacitance",and I can compile this project succefully,but I can't run "hello world" on it.
    anybody knows how to sotore data in SDRAM using DSP builder?
    thanks!!
