16 years agoddr2 sdram
Hello, I'am new to SOPC build,and sorry for my poor english. I have bought a dsp development kits from alter,and there is an ddr2 sdram on this development board. this is the development kits I...
16 years agoFirst of all you can not use 2 chip select cause the DDR2 you are using doesn't support two chip select.
Second, the automatic assignment you are talking about are pre-assigned since you are using the "standard" template. Finally, I am having the same problem when I am trying to increase the data width to 64-bit, it's something I cannot figure out!
