VMots's avatar
VMots
5 years ago
cascading pll with emif core (stratix10)
Hello!
I have several emif (ddr4) controllers which everyone have it's own reference clock (from package pin) but I want to feed it from pll when I connect it together and try to implement it I get next error messege (only one is shown):
Error(20181): The permit_cal input port of IOPLL "emif_ed_x7_inst|emif_x32_3|emif_x32_s10_2|arch|arch_inst|pll_inst|pll_inst" is not connected correctly. Enable and export the permit_cal port of downstream IOPLL "emif_ed_x7_inst|emif_x32_3|emif_x32_s10_2|arch|arch_inst|pll_inst|pll_inst" with the Platform Designer GUI and connect to the locked output of upstream IOPLL "u0|iopll_0|stratix10_altera_iopll_i|s10_iopll.fourteennm_pll"
but I do not find where to enable this port in the emif ip...
Can someone help me with this? Or may be advise another solution?
Best regards
  • VMots's avatar
    VMots
    One more addition: I use Quartus Prime pro 21.2.0
  • sstrell's avatar
    sstrell
    Are you trying to use the core clocks sharing option in the EMIF IP?
  • AdzimZM_Altera's avatar
    AdzimZM_Altera
    Hi VMots,
    I'm Adzim. Thank you for using the Intel Community.
    I've found a KDB for this error message. Link here.
    You might need to follow the resolution in there.
    I think you can enable it in the IOPLL IP under the Cascading tab.
    I share the screenshot for that.
    Please let me know if that helpful.
    Adzim
    • VMots's avatar
      VMots
      I am already see this solution but this is not iopll core but the emif core and it need to have permit_cal input.
    • VMots's avatar
      VMots
      That wasn't a question, how to connect two pll's.
      If you have 7 ddr memory controllers in one FPGA it require 14 pins for clock - it is too expensive while one is enough but looks like the intel not give us such possibility.
      While you feed ddr memory controllers from plls quartus give you error that you need to connect feedin pll pin with name pll_lock with ddr memory controller pll pin called permit_cal
      But permit_cal input is unaccessible from ip configurator
      • sstrell's avatar
        sstrell
        No, this is where you use the EMIF core clock sharing option I was asking about originally. You feed the clock to one EMIF and then that EMIF sends the clock to others. Again, there is no permit_cal pin because it's not part of the IP. The option you mention is for cascading PLLs (and just PLLs). From the EMIF parameterization training (https://www.intel.com/content/www/us/en/programmable/support/training/course/omem1122.html):
    AdzimZM_Altera
    Hi VMots,
    Do you can share the design with me so that I can replicate the error and debug it?
    Adzim
