Can I set a weak pull up resistor on an output port ?
The PFL we are using has a pull-up resistor 10K on the fpga_nconfig line (output from PFL within CPLD MAXV & input to the FPGA) but currently have issues of the fpga-nconfig line driven low somehow (cannot figure out).
I've seen on the internet comments from people saying the a weak pull up can be set only on input or bidirectional ports. Is this the case ?
Because when I set this manually within the .qsf for the output port fpga_nconfig :
set_instance_assignment -name WEAK_PULL_UP_RESISTOR ON -to fpga_nconfig
& later looked at the Assignment Editor, noticed that it accepted it as a weak pull up. But it replaced the:
- 'Assignment Name' from : Location -> Weak Pull-Up resistor
- 'Value' from: PIN_E5 -> On
Did not attempt to run this yet.
Where is eg the PIN_E5 pin location assignment gone for the fpga_nconfig pin? It's been now replaced by a Weak Pull-Up resistor and removed the PIN_E5 location assignment.
Please comment here !
Kevin
- Knug
Contributor
Replying to myself here. Resolved part of my query..
Ok, within the Assignment editor can also see further down the list the location assignment PIN_E5 for fpga_nconfig. So I could see that the 2 following location assignments I defined within my .qsf were both listed within the Assignmenr Editor window
set_location_assignment PIN_E5 -to fpga_nconfig
Q/ BUT is is ok to set a WEAK_PULL_UP_RESISTOR on an output port ?
If this is not ok, I must go and set this up from the FPGA side which is declared as an input port.
But it will not resolve the problem I am trying to resolve at the moment ie to why nconfig is pulled low after programming/configuring the loadware PFL code before even autodetecting the flash to program it with the main application code that later on should configure the FPGA
- Knug
Contributor
Can someone please answer my following question before end of the day, so I can attempt to try it out to see if it resolves my problem ?
Q / Is is ok to set a WEAK_PULL_UP_RESISTOR on an output port ?
& can I set a WEAK_PULL_UP_RESISTOR on a port that has already an external pull-up resistor of 10K ?
- Knug
Contributor
Tried the weak pull up resistor BUT it did not resolve the issue I had !
- NurAiman_M_Intel
Hi Kevin,
Apologize for the delay in response as I just received this case today.
Per my understanding from MAX V pin connection guidelines, connect this TMS and TDI input pins to a 10-kΩ pull-up resistor to VCCIO1.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/dp/max-v/pcg-01012.pdf
The Weak Pull-Up Resistor option should not be used at the same time as the Enable Bus-Hold Circuitry option. This option must be assigned to a pin or it is ignored.
Let me know if this is not the answer you are looking for as what I understand is you wanted to know if weal pull up resistor can be set to output port or not.
Aiman
- NurAiman_M_Intel
We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
- Knug
Contributor
I did not finally set a weak pull up resistor on fpga_nconfig.It had already a 10k pull-up.
I resolved the issue I had by myself to why FPGA was NOT configured after successful flash programming
Wrt other tickets raised had to delay the pfl_nreset to get the 1 PFL solution to work.
