Can I set a weak pull up resistor on an output port ?
Replying to myself here. Resolved part of my query..
Ok, within the Assignment editor can also see further down the list the location assignment PIN_E5 for fpga_nconfig. So I could see that the 2 following location assignments I defined within my .qsf were both listed within the Assignmenr Editor window
set_location_assignment PIN_E5 -to fpga_nconfig
set_instance_assignment -name WEAK_PULL_UP_RESISTOR ON -to fpga_nconfig
Q/ BUT is is ok to set a WEAK_PULL_UP_RESISTOR on an output port ?
If this is not ok, I must go and set this up from the FPGA side which is declared as an input port.
But it will not resolve the problem I am trying to resolve at the moment ie to why nconfig is pulled low after programming/configuring the loadware PFL code before even autodetecting the flash to program it with the main application code that later on should configure the FPGA
- Knug5 years ago
Contributor
Can someone please answer my following question before end of the day, so I can attempt to try it out to see if it resolves my problem ?
Q / Is is ok to set a WEAK_PULL_UP_RESISTOR on an output port ?
& can I set a WEAK_PULL_UP_RESISTOR on a port that has already an external pull-up resistor of 10K ?
- Knug5 years ago
Contributor
Tried the weak pull up resistor BUT it did not resolve the issue I had !
