Knug
Contributor
5 years agoCan I set a weak pull up resistor on an output port ?
The PFL we are using has a pull-up resistor 10K on the fpga_nconfig line (output from PFL within CPLD MAXV & input to the FPGA) but currently have issues of the fpga-nconfig line driven low som...
Knug
Contributor
5 years agoCan someone please answer my following question before end of the day, so I can attempt to try it out to see if it resolves my problem ?
Q / Is is ok to set a WEAK_PULL_UP_RESISTOR on an output port ?
& can I set a WEAK_PULL_UP_RESISTOR on a port that has already an external pull-up resistor of 10K ?
Knug
Contributor
5 years agoTried the weak pull up resistor BUT it did not resolve the issue I had !
