16 years agoaltsyncram simulation - X output?
I'm trying to simulate a dual-port block ram using altsyncram, but the output(q_a, q_b) of the block ram is X when initialized. According to manual it should be set to zero. I don't understand why this is happening - any suggestion will be appreciated. Following is the way I instantiate it:library ieee;
use ieee.std_logic_1164.all;
library altera_mf;
use altera_mf.all;
entity mem_2p_m9k is
generic(
addr_width : integer := 12;
num_words : integer := 4096;
data_width : integer := 16
port(
clk : in std_logic;
addr_a : in std_logic_vector(addr_width-1 downto 0);
addr_b : in std_logic_vector(addr_width-1 downto 0);
datain_a : in std_logic_vector(data_width-1 downto 0);
datain_b : in std_logic_vector(data_width-1 downto 0);
wren_a : in std_logic;
wren_b : in std_logic;
q_a : out std_logic_vector(data_width-1 downto 0);
q_b : out std_logic_vector(data_width-1 downto 0)
end mem_2p_m9k;
architecture arch of mem_2p_m9k is
component altsyncram
GENERIC (
address_reg_b : STRING;
clock_enable_input_a : STRING;
clock_enable_input_b : STRING;
clock_enable_output_a : STRING;
clock_enable_output_b : STRING;
indata_reg_b : STRING;
intended_device_family : STRING;
lpm_type : STRING;
numwords_a : NATURAL;
numwords_b : NATURAL;
operation_mode : STRING;
outdata_aclr_a : STRING;
outdata_aclr_b : STRING;
outdata_reg_a : STRING;
outdata_reg_b : STRING;
power_up_uninitialized : STRING;
ram_block_type : STRING;
read_during_write_mode_mixed_ports : STRING;
read_during_write_mode_port_a : STRING;
read_during_write_mode_port_b : STRING;
widthad_a : NATURAL;
widthad_b : NATURAL;
width_a : NATURAL;
width_b : NATURAL;
width_byteena_a : NATURAL;
width_byteena_b : NATURAL;
wrcontrol_wraddress_reg_b : STRING
PORT (
wren_a : IN STD_LOGIC ;
clock0 : IN STD_LOGIC ;
wren_b : IN STD_LOGIC ;
address_a : IN STD_LOGIC_VECTOR (11 DOWNTO 0);
address_b : IN STD_LOGIC_VECTOR (11 DOWNTO 0);
q_a : OUT STD_LOGIC_VECTOR (15 DOWNTO 0);
q_b : OUT STD_LOGIC_VECTOR (15 DOWNTO 0);
data_a : IN STD_LOGIC_VECTOR (15 DOWNTO 0);
data_b : IN STD_LOGIC_VECTOR (15 DOWNTO 0)
END COMPONENT;
begin
mem_inst: altsyncram
generic map(
address_reg_b => "CLOCK0",
clock_enable_input_a => "BYPASS",
clock_enable_input_b => "BYPASS",
clock_enable_output_a => "BYPASS",
clock_enable_output_b => "BYPASS",
indata_reg_b => "CLOCK0",
intended_device_family => "Stratix III",
lpm_type => "altsyncram",
numwords_a => num_words,
numwords_b => num_words,
operation_mode => "BIDIR_DUAL_PORT",
outdata_aclr_a => "NONE",
outdata_aclr_b => "NONE",
outdata_reg_a => "NONE",
outdata_reg_b => "NONE",
power_up_uninitialized => "FALSE",
ram_block_type => "M9K",
read_during_write_mode_mixed_ports => "DONT_CARE",
read_during_write_mode_port_a => "NEW_DATA_NO_NBE_READ",
read_during_write_mode_port_b => "NEW_DATA_NO_NBE_READ",
widthad_a => addr_width,
widthad_b => addr_width,
width_a => data_width,
width_b => data_width,
width_byteena_a => 1,
width_byteena_b => 1,
wrcontrol_wraddress_reg_b => "CLOCK0"
port map(
wren_a => wren_a,
clock0 => clk,
wren_b => wren_b,
address_a => addr_a,
address_b => addr_b,
q_a => q_a,
q_b => q_b,
data_a => datain_a,
data_b => datain_b
end arch;2 Replies
Either altera is not right or the simulator. If you have to initialise then use a mif or hex set to zeros.
Problem solved. I think it's due to my bad of wrapping another layer around generated core.
