16 years agoaltsyncram simulation - X output?
Hi, I'm trying to simulate a dual-port block ram using altsyncram, but the output(q_a, q_b) of the block ram is X when initialized. According to manual it should be set to zero. I don't underst...
16 years agoEither altera is not right or the simulator. If you have to initialise then use a mif or hex set to zeros.
