IOzan's avatar
IOzan
6 years ago
Altera PLL is not working
I'm trying to implement the Altera PLL from the IP catalog and no matter what I do- this simple cure is not working! (outclk_0 is constantly red signal in ModelSim). I'm working with Quartus Prime Lite Edition 17.1, ModelSim 10.5b and 5CEFA7F31I7 Cyclone V FPGA (EVM).
My ref clock is 50MHz and the desired and the actual is 48MHz. The other parameters are default (Direct, Integer-N PLL, Phase shift 0ps, D.C=50%, with locked output signal and input reset signal (active high but I even tried to toggle is in 1Hz).
What could possibly be the cause for the standard PLL cure???
Help…
Idan
  • AnandRaj_S_Intel's avatar
    AnandRaj_S_Intel
    Hi Idan,
    1. Have you applied reset?
    Try applying reset and given appropriate inputs to get the expected output.
    Anand
    • IOzan's avatar
      IOzan
      I did… as I mentioned, I even toggle the reset at 1Hz. The ref clk is always present at the input signal.
      What else can I do to operate the PLL cure?
      Help…
      Idan
    AnandRaj_S_Intel
    Hi Idan,
    Are you using just PLL IP stand-alone or initiating PLL IP on top-level HDL for simulation? Check the connectivity of the ports or pins.
    Try after deleting the work folder from the simulation directory.
    Attached some images.
    Anand
