Altera PLL is not working
Hi Idan,
Are you using just PLL IP stand-alone or initiating PLL IP on top-level HDL for simulation? Check the connectivity of the ports or pins.
Try after deleting the work folder from the simulation directory.
Attached some images.
Anand
Here are some snap shots from my code and simulation (and I'm attaching the project itself).
Help...
Idan
- IOzan6 years ago
And the complete code that is not working (PLL output is all red (U)).
What can I do to make it work?
Can you try to run the code in your Quartus and ModelSim versions?
Idan
- AnandRaj_S_Intel6 years ago
Hi Idan,
Your design looks good, You have to recheck the simulation steps. Please read msim_setup.tcl(Simple_counter_PLLC\Filter_PLL_C_sim\mentor) file which will help in simulation step if you have top level file.
I have attached the modelsim transcript and image. save below code as mentor.do and run
set QSYS_SIMDIR C:/<Directory>/Simple_counter_PLLC/Filter_PLL_C_sim source $QSYS_SIMDIR/mentor/msim_setup.tcl dev_com set TOP_LEVEL_NAME tb_Simple_counter elabRegards
Anand
