Altera PLL is not working
Hi Idan,
Are you using just PLL IP stand-alone or initiating PLL IP on top-level HDL for simulation? Check the connectivity of the ports or pins.
Try after deleting the work folder from the simulation directory.
Attached some images.
Anand
- IOzan6 years ago
Here are some snap shots from my code and simulation (and I'm attaching the project itself).
Help...
Idan
- IOzan6 years ago
And the complete code that is not working (PLL output is all red (U)).
What can I do to make it work?
Can you try to run the code in your Quartus and ModelSim versions?
Idan
- AnandRaj_S_Intel6 years ago
Hi Idan,
Your design looks good, You have to recheck the simulation steps. Please read msim_setup.tcl(Simple_counter_PLLC\Filter_PLL_C_sim\mentor) file which will help in simulation step if you have top level file.
I have attached the modelsim transcript and image. save below code as mentor.do and run
set QSYS_SIMDIR C:/<Directory>/Simple_counter_PLLC/Filter_PLL_C_sim source $QSYS_SIMDIR/mentor/msim_setup.tcl dev_com set TOP_LEVEL_NAME tb_Simple_counter elabRegards
Anand
