IOzan
6 years agoAltera PLL is not working
Hi, I'm trying to implement the Altera PLL from the IP catalog and no matter what I do- this simple cure is not working! (outclk_0 is constantly red signal in ModelSim). I'm working with Quart...
AnandRaj_S_Intel
6 years agoHi Idan,
- Have you applied reset?
Try applying reset and given appropriate inputs to get the expected output.
Anand
IOzan
6 years ago
I did… as I mentioned, I even toggle the reset at 1Hz. The ref clk is always present at the input signal.
What else can I do to operate the PLL cure?
Help…
Idan
