nalingam's avatar
nalingam
2 months ago
Altera Agilex PCIe core
Hi Altera Team,
We have developed a user reset controller based on the "Cold Reset Entry and Exit Sequence" described in the "GTS AXI Streaming IP for PCI Express User Guide for Agilex® 5 and Agilex® 3 FPGAs and SoCs".
Currently, our implementation is stalled at Step 2 of the reset sequence. Our user reset logic is waiting for the PCIe IP to assert the p<n>_initiate_warmrst_req signal; however, this signal is never asserted during simulation.
Our current PCIe configuration is as follows:
* PCIe x 4lanes
* AXI Streaming interface: 128-bit
* PLD clock: 200 MHz
* Reference clock: 100 MHz
* System PLL configured as required
Could you please advise on the possible reasons why p<n>_initiate_warmrst_req may not be asserting? Additionally, are there any configuration settings or reset timing requirements that must be satisfied before the PCIe IP generates this signal?
  • VenT_Altera's avatar
    VenT_Altera
    Hi nalingam,
    Apologies for the late reply.
    You can check the following:
    • p<n>_initiate_warmrst_req is an output from the IP to the user reset controller. For the PERST#-triggered cold-reset path, cold reset is initiated by deassertion of p<n>_pin_perst_n_i (PERST# released: low → high). The IP then asserts p<n>_initiate_warmrst_req, and your controller should respond with p<n>_subsystem_rst_req.
    • For a user-initiated cold reset, start by asserting p<n>_subsystem_rst_req. In that flow, initiate_warmrst_req is not the trigger and is not required.
    • Before PERST# deassertion in simulation, ensure ninit_done is 0 (device configured).
    • Compare your reset controller and PERST# timing against the design example generated in Quartus Prime for this IP. Refer to the following Design Example user guide for the steps to generate a Design Example: https://docs.altera.com/r/docs/817713/25.3/gts-axi-streaming-ip-for-pci-express-design-example-user-guide/about-the-gts-axi-streaming-ip-for-pci-express-design-example
    Ven
      VenT_Altera
      Hi nalingam,
      May I know if you have any updates on this forum?
      Ven
      • nalingam's avatar
        nalingam
        Hi Ven,
        Thank you for your response. Our team already working with Altera APS team to solve this issue. Please close this case for now.
    VenT_Altera
    Hi nalingam
    Thanks for reaching out to us.
    Please allow me sometime to investigate your issue, I will get back to you with an update shortly.
    Ven
