nalingam
3 months agoAltera Agilex PCIe core
Hi Altera Team, We have developed a user reset controller based on the "Cold Reset Entry and Exit Sequence" described in the "GTS AXI Streaming IP for PCI Express User Guide for Agilex® 5 and Agile...
VenT_Altera
2 months agoHi nalingam,
Apologies for the late reply.
You can check the following:
- p<n>_initiate_warmrst_req is an output from the IP to the user reset controller. For the PERST#-triggered cold-reset path, cold reset is initiated by deassertion of p<n>_pin_perst_n_i (PERST# released: low → high). The IP then asserts p<n>_initiate_warmrst_req, and your controller should respond with p<n>_subsystem_rst_req.
- For a user-initiated cold reset, start by asserting p<n>_subsystem_rst_req. In that flow, initiate_warmrst_req is not the trigger and is not required.
- Before PERST# deassertion in simulation, ensure ninit_done is 0 (device configured).
- Compare your reset controller and PERST# timing against the design example generated in Quartus Prime for this IP. Refer to the following Design Example user guide for the steps to generate a Design Example: https://docs.altera.com/r/docs/817713/25.3/gts-axi-streaming-ip-for-pci-express-design-example-user-guide/about-the-gts-axi-streaming-ip-for-pci-express-design-example
Ven
VenT_Altera
May I know if you have any updates on this forum?
Ven
- nalingam2 months ago
Hi Ven,
Thank you for your response. Our team already working with Altera APS team to solve this issue. Please close this case for now.
- VenT_Altera2 months ago
Hi nalingam,
Thanks for the updates.
I will proceed to transition this thread to Community support while you continue working on the issue with our APS support team.
Ven
