ALT LVDS RX IP does not support Frame clock ?
we are designing a LVDS receiver on Cyclone 10 LP which receives differential data from TI AWR6843 . We have 3 ports from AWR6843 that is
1. Differential data out,
2. Differential clock out
3. Differential frame clock.
These ports are not compatible with ALT LVDS RX IP.
TI AWR6843 has 4 channel ADC with 16 bits per sample which is given out through 2 lanes
at 600Mbps (300 MHz).
There is no input port available for frame clock. Is their any option available to implement LVDS receiver with frame clock? . Also what should be the pin mapping for this frame clock? .
Can you please specify what should be the PLL configurations to implement both bit clock & frame clock in a ALT LVDS receiver
Thanks & regards
vikas R
- FvM
quite obviously, a PLL can only have one input clock. A PLL operated LVDS receiver will typically only use the frame clock and generate the bit clock internally.
Frank
- vikas194
Hello frank, thanks for replying
Since we are using only frame clock, is it okay to discard bit clock (differential clock out from AWR6843)? if not, how can this clock be used?Also I wanted to know how rx_channel_data_align input has to be generated with respect to frame clock, since we don't have this logic in TI AWR6843 LVDS TX.
regards
Vikas
- FvM
please consider that I'm not familiar with the interface details of AWR6843.
In those cases where the frame clock corresponds to transmitted word boundary, you don't necessarily need the data align feature, just adjust the PLL slow clock phase so that you get the output right. That's at least what I'm doing with ADC LVDS interfaces.
- AqidAyman_Altera
Hi Vikas,
Do you have any more questions regarding this?
Aqid
- AqidAyman_Altera
As we do not receive any response from you on the previous question/reply/answer that we have provided, please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
