Agilex 5 SDI 148.5 and 148.35 MHz refclks
- 3 months ago
Hi yuriah726 ,
If I am going to have my own board instead of a devkit, then I will need to provide the FPGA with a reference clock signal that is multiplexed between 148.5 and 148.35 MHz, as well as implement the multiplexing control. Is this correct?
>> Yes. For Agilex 5 TX-only SDI, the expected approach is to externally select either 148.5 MHz or 148.35 MHz and feed that selected clock to the transceiver reference clock input.
Is there a way to provide both reference clocks to the IP and switch between them internally?
>> No. There is no Agilex 5 SDI II IP option in Quartus for internal switching between two reference clocks.
Hope this clarified.
Wincent_Altera
Hi yuriah726 ,
In the GTS SDI II IP User Guide, there is a set of parameters for "Transceiver reference clock frequency" and "Dynamic TX clock switching" under the category "Transceiver Options", however I don't see these parameters in Quartus. Is there somewhere else that I can enable this option to have the two different reference clock frequencies? Do I need this enabled, or is there some other way that I can switch between the two frequencies?
>> May I know which page / section you are looking for this information ?
>> Just trying to understand more so that we can speak apple to apple
Or do I need to provide both clock frequencies separately? If I need to provide both clock frequencies separately,
>> Altera recommends you not to share TX PLL reference clock with RX transceiver reference clock for a parallel loopback design because TX PLL clock is going to be tuned to match RX recovered clock frequency.
If I need to provide both clock frequencies separately, what pins can I use for the 148.35 MHz reference clock?
>> it depends on the device actually , but you can refer to our design example targeted the Agilex5 devkit, that can be a good reference to map the pin
>> Also you can refer to https://www.altera.com/design/devices/resources/pinouts#tab-blade-1-3
Wincent_Altera
