15 years ago
weird dma transfer behavoir
have set up a simple hardware system where the nios writes data to a on-chip fifo, and a dma transfer it back to sdram. datawidth is 32 all the way. i also use rxchan_ioctl to set dma to 32 bit
first i do 32 writes, seeminly okay - but when i tell the dma to get it i must set the length parameter to 128 to empty the fifo. why dont i fetch number of words equal to length?
also the first five words are not fetched correctly, why is that?
    Off the top of my head I'm not sure (I typically access the DMA registers directly.... and I haven't used that DMA in years). I would take a look at this document since the HAL portions of the DMA are documented in there: http://www.altera.com/literature/hb/nios2/n2sw_nii5v2.pdf Also I would use the macros in the DMA driver to read back the status register, you may see a bit in there that might explain what happened.
    i now do a alt_dcache_flush_all before i "rxchan_prepare", but the first five words are still not transfered. prepare simply dont put anything there.
    a new issue also came up. fifo_init now returns -1 wich means event clear error. what could cause this? an address issue?
    The length register uses a byte format. So to move 32 words of width 32-bits that's 128 bytes you are moving.
    If you are seeing data corruption make sure you are bypassing the cache or flushing it before kicking off the DMA.
