15 years agovht test bench examples
I am specifying altera to generate a .vht test bench for my vhdl project. I want to modify this test bench so that I can specify the input signals to be some value at different times instead of the current undefined (U). SIGNAL clk : STD_LOGIC; . . clk : IN STD_LOGIC; . . . clk => clk, . -- code that executes only once WAIT; END PROCESS init; always : PROCESS -- optional sensitivity list -- ( ) -- variable declarations BEGIN clk <='1'; wait for 10 ns; clk <='0'; wait for 10 ns; -- code executes for every event on sensitivity list --WAIT; I have been trying to find for hours some example modified test bench files that I can work off. The above code does not change the clock signal in the signal viewer in modelsim-altera at all. thank you12 Replies
Since you have not posted to the group enough, you probably cannot post your file to the group just yet, so just email it to the address given by my Altera forum name.
Cheers, Dave - Altera_Forum
--- Quote Start --- Okay it simulates now and I can drag signals over to the wave window. --- Quote End --- Great. --- Quote Start --- However, I still have undefined for the clock even with your specified code for the clock in the test bench. --- Quote End --- Post your testbench (.vht file) and I'll look at it. Cheers, Dave - Altera_Forum
Thank you,
Okay it simulates now and I can drag signals over to the wave window. However, I still have undefined for the clock even with your specified code for the clock in the test bench. - Altera_Forum
--- Quote Start --- When I typed : vsim Test_bench.vht Result:# OpenFile Test_bench.vht --- Quote End --- That is not the correct command. You need to drop the .vht. Cheers, Dave - Altera_Forum
When I typed :
vsim Test_bench.vht Result: # OpenFile Test_bench.vht The error is when I type "run 10 us" - Altera_Forum
--- Quote Start --- When I follow your instructions I get the error, "#No Design Loaded!" --- Quote End --- What happened when you typed 'vsim test_bench' (change the name to whatever your testbench is named of course)? That should load the design. Cheers, Dave - Altera_Forum
I am creating the test bench (vht file) by in Quartus: Processing -> Start -> start test bench writer The first couple lines in the file that is generated is: "-- *************************************************************************** -- This file contains a Vhdl test bench template that is freely editable to -- suit user's needs .Comments are provided in each section to help the user -- fill out necessary details. -- *************************************************************************** -- Generated on "07/06/2011 10:00:43" -- Vhdl Test Bench template for design :" - Altera_Forum
--- Quote Start --- In Quartus I made a vht test bench file. When I compile quartus I tell it to run the test bench in modelsim. --- Quote End --- I run Modelsim independently of Quartus, so I don't know exactly what is going on. However, here's what should be happening. If Quartus is creating an entity called test_bench, and inside that entity is where you have your clocks and input stimulus, then in Modelsim you can do the following;
Try that. Cheers, Dave# Stop the current simulation quit -sim # Simulate the test_bench design vsim test_bench # Run the simulation for 10 microseconds run 10 us # I've made some edits, now I want to re-run# # First rebuild the VHDL files that I've edited vcom test_bench.vhd# # Force the design changes to be loaded restart -f# # Run the design to see if my edits worked ... run 10 us - Altera_Forum
Thank you for the help
In Quartus I made a vht test bench file. When I compile quartus I tell it to run the test bench in modelsim. When modelsim loads it lists all the signals in the Objects window and loads the wave window. All my input signals are being shown as undefined, however it does show signals being propagated internally within my system (which is to be expected, not everything in my system is dependent on an input signal). - Altera_Forum
--- Quote Start --- However it is still not showing up on my signal viewer. --- Quote End --- How are you adding the signal to the viewer? You have to drag it from the signals list into the viewer. Assuming you're new to Modelsim, do the following ... In Modelsim, display the signals and wave window view signals wave then add all top-level signals add wave * then delete the ones you do not want to see, and select levels of the hierarchy to view the signals at that level of the design, and drag them across to the wave window. Right click and add dividers where you want to name blocks of signals, and then save it as a 'wave.do' file, or name of your choice, then later you can just type 'vsim mytest; do wave.do' to populate the wave window. Cheers, Dave
