15 years agovht test bench examples
Hello, I am specifying altera to generate a .vht test bench for my vhdl project. I want to modify this test bench so that I can specify the input signals to be some value at different times ins...
15 years agoWhen I follow your instructions I get the error, "#No Design Loaded!"
I am creating the test bench (vht file) by in Quartus: Processing -> Start -> start test bench writer The first couple lines in the file that is generated is: "-- *************************************************************************** -- This file contains a Vhdl test bench template that is freely editable to -- suit user's needs .Comments are provided in each section to help the user -- fill out necessary details. -- *************************************************************************** -- Generated on "07/06/2011 10:00:43" -- Vhdl Test Bench template for design :"
