14 years ago
VHDL waveform simulation problems
Hello everyone, this is my first post here.
Thanks in advance for reading my problem.
Well, I have to create a vhdl code for a 2bit counter, which receives 8bits, and adds 1 to the counter for every '1' inside those 8bits
To do so, I used a shifter for A within a loop. And designed it to add counter by 1 when A(0) = '1'
It compiled succesfully, but when I tried to simulate it with a waveform file,
for every clock pulse the "count" was added by 1, and after 3 clock cycles, the "count" reached its limit (11) and reseted. The value of "count" didnt even obeyed the reset or enable values.
Maybe the code isn't proper for what I want, cause I'm a beginner trying to learn by myself. Or maybe I'm simulating it wrongly, also because I'm a beginner, haha.
hope someone help me :).
Vhdl code:
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity contador_acertos is
port (clock, reset, enable : in std_logic;
acertos : in std_logic_vector(7 downto 0);
contador : out std_logic_vector(1 downto 0)
end contador_acertos;
architecture behavior_contagem of contador_acertos is
signal count : std_logic_vector(1 downto 0);
signal A : std_logic_vector(7 downto 0);
begin
process (clock, acertos, enable)
begin
if (reset = '1') then
count <= "00";
elsif (clock'event and clock = '1') then
if (enable <= '1') then
A <= acertos;
count <= "00";
oito : for i in 7 downto 0 loop
if (A(0) <= '1') then
count <= count + 1;
A(6 downto 0) <= A(7 downto 1);
else
end if;
end loop oito;
end if;
end if;
end process;
contador <= count;
end behavior_contagem;
Thank you!
    You have implemented a kind of state machine to perform the intended action sequentially, one bit per clock cycle.
    That's the other solution for the present problem if the involved logic is too complex to determine the result in a single clock cycle. In the present case, a parallel solution as sketched in my previous post should perfectly work.
    Technically, there are several points that possibly need to be changed with your code to use it in a real word application, but you'll surely find out when using it.
    I just nailed it!!!!
    I'll post it here, maybe someone will need it later.
    The problem as I suspected was that S wasn't declared.
    So to fix it, you have to write
    signal S: std_logic_vector(7 downto 0):= (others => '0');
    Yea, that was the problem...
    ...sigh "makes gun shape with hand, points to head, bang"
    Sorry for changing things too fast, but it took so long for someone to repost so I created it differently, but still not working...
    it looks like my problem is with "cont" and "C". The code compile and looks fine, but the cont doesnt add when I simulate through vector waveform file with saida_reg_esquadra(7)='1' and
    saida_reg_disparo(7)= '1'
    in this code, when both "saidas" are 1, the cont is added by 1 only once
    is it not working because cont is assigned to C within the process?
    or because I should initiate signal S with 00000000?
    have no idea, im struggling with this since today's morning
    Now my new code is
    library ieee;
    entity comparador is
    port (
    clock : in std_logic;
    reset : in std_logic;
    saida_reg_esquadra : in std_logic_vector(7 downto 0);
    saida_reg_disparo : in std_logic_vector(7 downto 0);
    C : out std_logic_vector(1 downto 0)
    end comparador;
    architecture behavior of comparador is
    signal S: std_logic_vector(7 downto 0);
    signal cont: std_logic_vector(1 downto 0);
    begin
    process(clock, saida_reg_esquadra, saida_reg_disparo, reset)
    begin
    cont <="00";
    elsif (clock'event and clock='1') then
    if (saida_reg_esquadra(0) = '1' and saida_reg_disparo(0) ='1' and S(0) = '0') then
    cont <= cont +1;
    S(0) <='1';
    elsif (saida_reg_esquadra(1) = '1' and saida_reg_disparo(1) ='1' and S(1) = '0') then
    cont <= cont +1;
    S(1) <='1';
    elsif (saida_reg_esquadra(2) = '1' and saida_reg_disparo(2) ='1' and S(2) = '0') then
    cont <= cont +1;
    S(2) <='1';
    elsif (saida_reg_esquadra(3) = '1' and saida_reg_disparo(3) ='1' and S(3) = '0') then
    cont <= cont +1;
    S(3) <='1';
    elsif (saida_reg_esquadra(4) = '1' and saida_reg_disparo(4) ='1' and S(4) = '0') then
    cont <= cont +1;
    S(4) <='1';
    elsif (saida_reg_esquadra(5) = '1' and saida_reg_disparo(5) ='1' and S(5) = '0') then
    cont <= cont +1;
    S(5) <='1';
    elsif (saida_reg_esquadra(6) = '1' and saida_reg_disparo(6) ='1' and S(6) = '0') then
    cont <= cont +1;
    S(6) <='1';
    elsif (saida_reg_esquadra(7) = '1' and saida_reg_disparo(7) ='1' and S(7) = '0') then
    cont <= cont +1;
    S(7) <='1';
    end if;
    end if;
    C <= cont;
    end process;
    end behavior;
    Thanks for replying
    About the counter, I know it will always receive 8bits with no more than 3 '1' bit.
    I admit I still have some issues to completely understand the use of signals.
    I tried to fix it doing as you adviced
    count is now a variable, I didn't know if I could assing a variable to an output
    so I created another signal, "conta", and assigned the variable count to it inside the process, and so assigned "conta" to the output "contador" outside the process
    Now the "contador" isn't adding for every clock pulse anymore, as a matter of fact, it isn't adding even when A(i) <= '1'.
    I guess there may be a problem the way I attached the signals and variable inside/outside the process.
    If my question is too basic, I would appreciate a link where I could understand it thoroughly. I got to send a project next friday.
    Right now the code is like:
    library ieee;
    signal conta : std_logic_vector(1 downto 0);
    begin
    A <= acertos;
    process (clock, acertos, enable, reset)
    variable count : std_logic_vector(1 downto 0);
    begin
    count := "00";
    count := "00";
    if (A(i) <= '1') then
    count := count + 1;
    end if;
    end loop oito;
    end if;
    end if;
    conta <= count;
    end process;
    contador <= conta;
    The basic problem is that all signal assignments in the sequential code take effect after the end of the process. This also applies to iteration loops. In other words, the for loop has no effect at all.
    Variable are in contrast updated immediately. A simple implementation can look like this, where count has to be defined as a variable inside the process. I suggest to review the topic in a VHDL text book or tutorial and won't give lengthy explanations on it.
    count := "00";
        count := count + 1;
      end if;
    end loop;
    To represent the full range of 0 to 8 '1' bits, a 4-Bit counter would be required.
