14 years agoVHDL waveform simulation problems
Hello everyone, this is my first post here. Thanks in advance for reading my problem. Well, I have to create a vhdl code for a 2bit counter, which receives 8bits, and adds 1 to the counter fo...
14 years agoSorry for changing things too fast, but it took so long for someone to repost so I created it differently, but still not working...
it looks like my problem is with "cont" and "C". The code compile and looks fine, but the cont doesnt add when I simulate through vector waveform file with saida_reg_esquadra(7)='1' and saida_reg_disparo(7)= '1' in this code, when both "saidas" are 1, the cont is added by 1 only once is it not working because cont is assigned to C within the process? or because I should initiate signal S with 00000000? have no idea, im struggling with this since today's morning Now my new code is library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; entity comparador is port ( clock : in std_logic; reset : in std_logic; saida_reg_esquadra : in std_logic_vector(7 downto 0); saida_reg_disparo : in std_logic_vector(7 downto 0); C : out std_logic_vector(1 downto 0) ); end comparador; architecture behavior of comparador is signal S: std_logic_vector(7 downto 0); signal cont: std_logic_vector(1 downto 0); begin process(clock, saida_reg_esquadra, saida_reg_disparo, reset) begin if (reset = '1') then cont <="00"; elsif (clock'event and clock='1') then if (saida_reg_esquadra(0) = '1' and saida_reg_disparo(0) ='1' and S(0) = '0') then cont <= cont +1; S(0) <='1'; elsif (saida_reg_esquadra(1) = '1' and saida_reg_disparo(1) ='1' and S(1) = '0') then cont <= cont +1; S(1) <='1'; elsif (saida_reg_esquadra(2) = '1' and saida_reg_disparo(2) ='1' and S(2) = '0') then cont <= cont +1; S(2) <='1'; elsif (saida_reg_esquadra(3) = '1' and saida_reg_disparo(3) ='1' and S(3) = '0') then cont <= cont +1; S(3) <='1'; elsif (saida_reg_esquadra(4) = '1' and saida_reg_disparo(4) ='1' and S(4) = '0') then cont <= cont +1; S(4) <='1'; elsif (saida_reg_esquadra(5) = '1' and saida_reg_disparo(5) ='1' and S(5) = '0') then cont <= cont +1; S(5) <='1'; elsif (saida_reg_esquadra(6) = '1' and saida_reg_disparo(6) ='1' and S(6) = '0') then cont <= cont +1; S(6) <='1'; elsif (saida_reg_esquadra(7) = '1' and saida_reg_disparo(7) ='1' and S(7) = '0') then cont <= cont +1; S(7) <='1'; end if; end if; C <= cont; end process; end behavior;
