14 years agoVHDL waveform simulation problems
Hello everyone, this is my first post here. Thanks in advance for reading my problem. Well, I have to create a vhdl code for a 2bit counter, which receives 8bits, and adds 1 to the counter fo...
14 years agoThanks for replying
About the counter, I know it will always receive 8bits with no more than 3 '1' bit. I admit I still have some issues to completely understand the use of signals. I tried to fix it doing as you adviced count is now a variable, I didn't know if I could assing a variable to an output so I created another signal, "conta", and assigned the variable count to it inside the process, and so assigned "conta" to the output "contador" outside the process Now the "contador" isn't adding for every clock pulse anymore, as a matter of fact, it isn't adding even when A(i) <= '1'. I guess there may be a problem the way I attached the signals and variable inside/outside the process. If my question is too basic, I would appreciate a link where I could understand it thoroughly. I got to send a project next friday. Right now the code is like: library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; entity contador_acertos is port (clock, reset, enable : in std_logic; acertos : in std_logic_vector(7 downto 0); contador : out std_logic_vector(1 downto 0) ); end contador_acertos; architecture behavior_contagem of contador_acertos is signal A : std_logic_vector(7 downto 0); signal conta : std_logic_vector(1 downto 0); begin A <= acertos; process (clock, acertos, enable, reset) variable count : std_logic_vector(1 downto 0); begin if (reset = '1') then count := "00"; elsif (clock'event and clock = '1') then if (enable <= '1') then count := "00"; oito : for i in 7 downto 0 loop if (A(i) <= '1') then count := count + 1; end if; end loop oito; end if; end if; conta <= count; end process; contador <= conta; end behavior_contagem;
