8 years ago
[VHDL] 'else generate' is not supported ...
Hi All,
I'm receiving the following error during my code compilation:
(vcom-1440) Language feature ELSE GENERATE STATEMENT is not supported yet
From what Quartus version is this feature supported?
Here is my code:
     gen_flr_cnt : if (tbl(i).sbit = flr_cnt or tbl(i).pbit = flr_cnt or tbl(i).ibit = flr_cnt) generate
      i_flr_cnt : entity work.flr_cnt
          generic map(
              TRSH =>FLR_CNT_TRSH
          port map(
              clk     => clk,
              rstn    => rstn,
              clr     => cnt_clr,
              flr_in  => bit_vec(i),
              flr_out => flr_cnt_res(i)
      else generate    flr_cnt_res(i) <= '0';
     end generate gen_flr_cnt;
Thank you!
    Standard edition or Pro? I think it may be a Pro edition only feature.
    Actually I tried this sintax in another Quartus 16 and it passed there...
    Any clue? In both the file was defined as VHDL-2008
    How could it be?
    Well if it's saying it's not supported, you'll have to use separate generate statements.
    What quartus version are you using" - Quartus v16
    I am a bit suspicious of your generate expression though. Is it really static?" - yes, all elements inside of 'if' are constants
    I was under the impression that else generate had been supported for a while. What quartus version are you using.
    You are ahead of vhdl standards. You can split generate into two sections:
    if true generate
    end generate;
    if false generate
    end generate;
