14 years ago
VHDL and VERILOG how i can connect together.
How i can integrate a verilog code into an VHDL code?
I have a code in verilog and i want to use it together with a vhdl code how can i do it ?
    this is a VHDL code .i want this code in Verilog but i could not do it...
    library IEEE;
    use IEEE.std_logic_1164.all;
    use ieee.numeric_std.all;
    entity PowerControl is
    port (
    Clk : in std_logic;
    Reset : in std_logic;
    ms : in std_logic
    -- xbus_hw_idct enable bit
    pse_m : out std_logic);
    --IDCT switch and isolation control power shut off
    end;
    architecture rtl of PowerControl is
    type state_type is (S0, S00, S01);
    signal state_m,nstate_m: state_type;
    signal m:std_logic;
    signal c_delay_cycles_S00,n_delay_cycles_S00: natural range 0 to 2; --delay counter for mode 0
    begin
    seq: process (Clk,Reset,nstate_m,n_delay_cycles_S00)
    begin
    if Reset = '0' then
    state_m<=S0;
    elsif falling_edge(Clk) then
    state_m<=nstate_m;
    c_delay_cycles_S00<=n_delay_cycles_S00;
    end if;
    end process seq;
    comb_m: process (ms,state_m,c_delay_cycles_S00)
    begin
    case state_m is
    when S0 => --Starting State
    n_delay_cycles_S00<=0;
    m<='1';
    if ms= "0" then
    nstate_m<=S00;
    elsif ms= "1" then
    nstate_m<=S01;
    else
    nstate_m<=S0;
    end if;
    when S00 => --Mode 0 - Multiplier OFF
    if ms = "1" then
    n_delay_cycles_S00 <= 0;
    m<='1';
    nstate_m<=S01;
    elsif ms= "0" then
    if c_delay_cycles_S00 < 2 then
    m<='1';
    n_delay_cycles_S00 <= c_delay_cycles_S00 + 1;
    else
    m<='0';
    end if;
    else
    m<='1';
    nstate_m<=S0;
    end if;
    when S01 => --Mode 0 - Multiplier ON
    m<='1';
    if ms = "0" then
    n_delay_cycles_S00 <= 1;
    nstate_m<=S00;
    elsif ms= "1" then
    nstate_m<=S01;
    else
    nstate_m<=S0;
    end rtl;
    --- Quote Start ---
    I already have the verilog code for the G-sensor of my board(DE0-Nano) , when the board is rotating then the 8 led are flashing. I want to write a code that will record data (X Y Z) from the movement of the board and store the data to the 32MB memory.
    I'm a little bit of VHDL user and i don't know nothing about verilog.
    --- Quote End ---
    Port the Verilog code to VHDL.
    The G-sensor interface is probably just a finite-state-machine and control data path.
    Synchronous logic: always @ (posedge clk, negedge reset_n) becomes process(clk, rstN)
    Asynchronous logic:always @ (a, b, c) becomes process (a, b, c)
    Asynchronous logic:assign a = b; becomes a <= b;
    However, if the Verilog code is unreadable, then its pointless porting it. Just write it yourself.
    Cheers,
    Dave
    Thanks for your quick response Dave.
    I appriciate any help of you
    And remember that the basic version of Modelsim don't allow you to mix vhdl and verilog in a project. So if you need to simulate it you'd better have everything in the same language.
    --- Quote Start ---
    can you send me any link with example and tutorial
    --- Quote End ---
    For what? I typically use Google when I have a Verilog question, and for VHDL I have a few books, eg., Ashenden, "The designers guide to VHDL".
    --- Quote Start ---
    is for my individual project in the final year and i'm lost
    --- Quote End ---
    What do you actually have to do for your final project? There is really no need to mix VHDL and Verilog if you are writing your own code. If you only have a few Verilog source files and you want to use VHDL, just port them. The basic language syntax is really not that different. Alternatively, port the VHDL to Verilog/SystemVerilog. The free Altera simulator only lets you simulate one language at a time.
    Are you using the Modelsim simulator for development? If not, you should be. Modelsim and Altera have plenty of tutorials.
    Cheers,
    Dave
    thanks Dave,
    i appreciate your quick response and your help.
    (is for my individual project in the final year and i'm lost:(.....
    VHDL code likes to see a component definition to tell it what the connectivity is.
    So if I have a Verilog module called 'example' with a clock and reset input, and a d input and q output, then in the VHDL file in the architecture section you need:
    architecture ...
       -- Verilog component
       component example
           port (
              reset : in std_logic;
              clock : in std_logic;
              d      : in std_logic;
              q      : out std_logic
       end component;
       signal reset, clock, d, q : std_logic;
    begin
        u1: example
        port map (
            reset => reset,
            clock => clock,
            d      => d,
            q      => q
    end architecture;
    Cheers,
    Dave
