14 years agoVHDL and VERILOG how i can connect together.
How i can integrate a verilog code into an VHDL code? I have a code in verilog and i want to use it together with a vhdl code how can i do it ?
14 years agoVHDL code likes to see a component definition to tell it what the connectivity is.
So if I have a Verilog module called 'example' with a clock and reset input, and a d input and q output, then in the VHDL file in the architecture section you need:
architecture ...
-- Verilog component
component example
port (
reset : in std_logic;
clock : in std_logic;
d : in std_logic;
q : out std_logic
end component;
signal reset, clock, d, q : std_logic;
begin
u1: example
port map (
reset => reset,
clock => clock,
d => d,
q => q
end architecture;
Cheers, Dave
