14 years agoVHDL and VERILOG how i can connect together.
How i can integrate a verilog code into an VHDL code? I have a code in verilog and i want to use it together with a vhdl code how can i do it ?
14 years agothis is a VHDL code .i want this code in Verilog but i could not do it...
library IEEE; use IEEE.std_logic_1164.all; use ieee.numeric_std.all; entity PowerControl is port ( Clk : in std_logic; Reset : in std_logic; ms : in std_logic -- xbus_hw_idct enable bit pse_m : out std_logic); --IDCT switch and isolation control power shut off end; architecture rtl of PowerControl is type state_type is (S0, S00, S01); signal state_m,nstate_m: state_type; signal m:std_logic; signal c_delay_cycles_S00,n_delay_cycles_S00: natural range 0 to 2; --delay counter for mode 0 begin seq: process (Clk,Reset,nstate_m,n_delay_cycles_S00) begin if Reset = '0' then state_m<=S0; elsif falling_edge(Clk) then state_m<=nstate_m; c_delay_cycles_S00<=n_delay_cycles_S00; end if; end process seq; comb_m: process (ms,state_m,c_delay_cycles_S00) begin case state_m is when S0 => --Starting State n_delay_cycles_S00<=0; m<='1'; if ms= "0" then nstate_m<=S00; elsif ms= "1" then nstate_m<=S01; else nstate_m<=S0; end if; when S00 => --Mode 0 - Multiplier OFF if ms = "1" then n_delay_cycles_S00 <= 0; m<='1'; nstate_m<=S01; elsif ms= "0" then if c_delay_cycles_S00 < 2 then m<='1'; n_delay_cycles_S00 <= c_delay_cycles_S00 + 1; else m<='0'; end if; else m<='1'; nstate_m<=S0; end if; when S01 => --Mode 0 - Multiplier ON m<='1'; if ms = "0" then n_delay_cycles_S00 <= 1; nstate_m<=S00; elsif ms= "1" then nstate_m<=S01; else nstate_m<=S0; end rtl;
