15 years agoVHDL - FSM Design
I've posted this on comp.lang.vhdl, but it seems to be overridden with spam these days, so I don't think anyone will see it. I'm learning about FSMs and I'm having a hard time getting my code to run correctly. I'm getting errors that say the registers for my states won't hold outside of the clock edge, and another set of errors saying that i have multiple constant drivers that can't be resolved. Does anyone think that they could help me out with this code? I've truncated the switch, the full source can be found here http://paste.org/pastebin/view/26824 Thanks MalikLIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.numeric_std.all;
entity part1take2 is
port(
CLOCK_50 : in std_logic;
SW : in unsigned(1 downto 0);
LEDR : out unsigned(8 downto 0)
end part1take2;
architecture behavioral of part1take2 is
type statet is ( A, B, C, D, E, F, G, H, I );
constant FMil: integer := 50000000;
signal count : unsigned(25 downto 0);
signal CLK : std_logic;
signal cstate, nstate : statet;
signal lstate : unsigned(8 downto 0);
begin
LEDR <= lstate;
process(CLK, SW, cstate)
begin
nstate <= cstate;
LEDR <= to_unsigned(0, 9);
if(SW(0) = '1') then
nstate <= A;
else
if(rising_edge(CLK)) then
case cstate is
when A =>
lstate <= to_unsigned(000000001, 9);
if(SW(1) = '1') then
nstate <= F;
else
nstate <= B;
end if;
when B =>
lstate <= to_unsigned(000000010, 9);
nstate <= F;
else
nstate <= C;
end if;
t--truncated
end case;
end if;
end if;
end process;
process(CLOCK_50) begin
if rising_edge(CLOCK_50) then
if(count = FMil) then
CLK <= (not CLK);
if(CLK = '1') then
cstate <= nstate;
end if;
else
count <= count + 1;
end if;
end if;
end process;
end behavioral;8 Replies
very cool trick, thanks.
x"123ABC" represents a string with hexedecimal represenation. It can be mapped easily to any array of bit or std_logic (bit_vector, std_logic_vector, unsigned, signed, ufxied, sfixed).
to_unsigned is a function that converts an integer into an unsigned type (which is an array of std_logic). VHDL is strongly typed, and so you have to be careful. PS. if you actually want a number in binary assigned to led, you can do this: led <= to_unsigned(2#000001000#, 9); The 2#N# tells the compiler the number between the hashes is in base 2. otherwise it defaults to base 10. - Altera_Forum
what in the world just happened!? you mean to tell me that double quotes could make all the difference?? VHDL can be so cruel sometimes!! :/
someone please enlighten me. :( -edit- some associates just laughed at me and explained that "x" is bit vector and to_unsigned(x,x) is integer - Altera_Forum
I guess, you intendled <= to_unsigned(000001000, 9);led <= "000001000" - Altera_Forum
hmm the clocking seems fine now, thanks.
The state machine's LEDs seem to be going crazy thoughLIBRARY ieee; USE ieee.std_logic_1164.all; USE ieee.numeric_std.all; entity part1take2 is port( CLOCK_50 : in std_logic; SW : in unsigned(1 downto 0); LEDR : out unsigned(16 downto 0) ); end part1take2; architecture behavioral of part1take2 is type statet is ( A, B, C, D, E, F, G, H, I ); constant FMil: integer := 50000000; constant kk25: integer := 25000000; signal count : unsigned(25 downto 0); signal CLK : std_logic; signal cstate, nstate : statet; signal led : unsigned(8 downto 0); signal cled : unsigned(7 downto 0); begin LEDR(8 downto 0) <= led; LEDR(16 downto 9) <= cled; process(SW, cstate) begin if(SW(0) = '1') then nstate <= A; else case cstate is when A => led <= to_unsigned(000000001, 9); if(SW(1) = '1') then nstate <= F; else nstate <= B; end if; when B => led <= to_unsigned(000000010, 9); if(SW(1) = '1') then nstate <= F; else nstate <= C; end if; when C => led <= to_unsigned(000000100, 9); if(SW(1) = '1') then nstate <= F; else nstate <= D; end if; when D => led <= to_unsigned(000001000, 9); if(SW(1) = '1') then nstate <= F; else nstate <= E; end if; when E => led <= to_unsigned(000010000, 9); if(SW(1) = '1') then nstate <= F; else nstate <= E; end if; when F => led <= to_unsigned(000100000, 9); if(SW(1) = '1') then nstate <= G; else nstate <= B; end if; when G => led <= to_unsigned(001000000, 9); if(SW(1) = '1') then nstate <= H; else nstate <= B; end if; when H => led <= to_unsigned(010000000, 9); if(SW(1) = '1') then nstate <= I; else nstate <= B; end if; when I => led <= to_unsigned(100000000, 9); if(SW(1) = '1') then nstate <= I; else nstate <= B; end if; end case; end if; end process; process(CLOCK_50) begin if rising_edge(CLOCK_50) then if(count = kk25) then CLK <= (not CLK); count <= to_unsigned(0, 26); if(CLK = '1') then cstate <= nstate; cled <= cled + 1; end if; else count <= count + 1; end if; end if; end process; end behavioral; - Altera_Forum
hello,
Thanks I did notice those mistakes and changed them, but my code still runs weird. I'm trying to figure out the problem now. I'm trying to learn how to use signal tap. Maybe that can tell me something about what's going on.LIBRARY ieee; USE ieee.std_logic_1164.all; USE ieee.numeric_std.all; entity part1take2 is port( CLOCK_50 : in std_logic; SW : in unsigned(1 downto 0); LEDR : out unsigned(16 downto 0) ); end part1take2; architecture behavioral of part1take2 is type statet is ( A, B, C, D, E, F, G, H, I ); constant FMil: integer := 50000000; signal count : unsigned(25 downto 0); signal CLK : std_logic; signal cstate, nstate : statet; signal led : unsigned(8 downto 0); signal cled : unsigned(7 downto 0); begin LEDR(8 downto 0) <= led; LEDR(16 downto 9) <= cled; process(SW, cstate) begin if(SW(0) = '1') then nstate <= A; else case cstate is when A => led <= to_unsigned(000000001, 9); if(SW(1) = '1') then nstate <= F; else nstate <= B; end if; when B => led <= to_unsigned(000000010, 9); if(SW(1) = '1') then nstate <= F; else nstate <= C; end if; when C => led <= to_unsigned(000000100, 9); if(SW(1) = '1') then nstate <= F; else nstate <= D; end if; when D => led <= to_unsigned(000001000, 9); if(SW(1) = '1') then nstate <= F; else nstate <= E; end if; when E => led <= to_unsigned(000010000, 9); if(SW(1) = '1') then nstate <= F; else nstate <= E; end if; when F => led <= to_unsigned(000100000, 9); if(SW(1) = '1') then nstate <= G; else nstate <= B; end if; when G => led <= to_unsigned(001000000, 9); if(SW(1) = '1') then nstate <= H; else nstate <= B; end if; when H => led <= to_unsigned(010000000, 9); if(SW(1) = '1') then nstate <= I; else nstate <= B; end if; when I => led <= to_unsigned(100000000, 9); if(SW(1) = '1') then nstate <= I; else nstate <= B; end if; end case; end if; end process; process(CLOCK_50) begin if rising_edge(CLOCK_50) then count <= count + 1; cled <= cled + 1; if(count = FMil) then CLK <= (not CLK); if(CLK = '1') then cstate <= nstate; end if; end if; end if; end process; end behavioral; - Altera_Forum
decide about LEDR: is it assigned lstate or 9 ???
follow the clk temp;late below. your clocking is not healthy even if you get no errors.
comment out the extra end if; at endLEDR <= lstate; process(CLK, SW, cstate) begin --nstate <= cstate; --LEDR <= to_unsigned(0, 9); if(SW(0) = '1') then nstate <= A; elsif(rising_edge(CLK)) then case cstate is... - Altera_Forum
cstate <= nstate; <- It needs edge-triggered.
nstate decoding DOES NOT need edge trigger. So, you need at least TWO processes.
