15 years agoVHDL - FSM Design
Hello, I've posted this on comp.lang.vhdl, but it seems to be overridden with spam these days, so I don't think anyone will see it. I'm learning about FSMs and I'm having a hard time getting my ...
15 years agohmm the clocking seems fine now, thanks.
The state machine's LEDs seem to be going crazy thoughLIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.numeric_std.all;
entity part1take2 is
port(
CLOCK_50 : in std_logic;
SW : in unsigned(1 downto 0);
LEDR : out unsigned(16 downto 0)
end part1take2;
architecture behavioral of part1take2 is
type statet is ( A, B, C, D, E, F, G, H, I );
constant FMil: integer := 50000000;
constant kk25: integer := 25000000;
signal count : unsigned(25 downto 0);
signal CLK : std_logic;
signal cstate, nstate : statet;
signal led : unsigned(8 downto 0);
signal cled : unsigned(7 downto 0);
begin
LEDR(8 downto 0) <= led;
LEDR(16 downto 9) <= cled;
process(SW, cstate)
begin
if(SW(0) = '1') then
nstate <= A;
else
case cstate is
when A =>
led <= to_unsigned(000000001, 9);
if(SW(1) = '1') then
nstate <= F;
else
nstate <= B;
end if;
when B =>
led <= to_unsigned(000000010, 9);
nstate <= F;
else
nstate <= C;
end if;
when C =>
led <= to_unsigned(000000100, 9);
nstate <= F;
else
nstate <= D;
end if;
when D =>
led <= to_unsigned(000001000, 9);
nstate <= F;
else
nstate <= E;
end if;
when E =>
led <= to_unsigned(000010000, 9);
nstate <= F;
else
nstate <= E;
end if;
when F =>
led <= to_unsigned(000100000, 9);
nstate <= G;
else
nstate <= B;
end if;
when G =>
led <= to_unsigned(001000000, 9);
nstate <= H;
else
nstate <= B;
end if;
when H =>
led <= to_unsigned(010000000, 9);
nstate <= I;
else
nstate <= B;
end if;
when I =>
led <= to_unsigned(100000000, 9);
nstate <= I;
else
nstate <= B;
end if;
end case;
end if;
end process;
process(CLOCK_50) begin
if rising_edge(CLOCK_50) then
if(count = kk25) then
CLK <= (not CLK);
count <= to_unsigned(0, 26);
if(CLK = '1') then
cstate <= nstate;
cled <= cled + 1;
end if;
else
count <= count + 1;
end if;
end if;
end process;
end behavioral;
